CISCO 2911 bootup issues.
hodgey1987
Community Member
Hi All,
Just a quick question, i have a 2911 as stated above which come with a base IOS of: c2900-universalk9-mz.SPA.152-4.M2.bin
I have downgraded the image to: c2900-universalk9-mz.SPA.150-1.M7.bin, however when the router initially boots i receive:
csdb tcp synwait-time 30
% Invalid input detected at '^' marker.
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
% Incomplete command.
shutdown
No physical hardware support for line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
Is this something to do with the image i have downgraded to?
Cheers
mfurnival
Level 10
Level 10
The errors you are seeing suggest that there are commands in your startup config that are not supported in the version of IOS you are using. This is to be expected if you go from a newer to an older version of IOS. It may or may not effect the functionality of your setup - it depends what you are trying to do...
