Cisco 881G DHCP issue
Brendon Bell
I would like to configure the 881G to use both the cellular interface and Fe4 WAN port for internet connectivity.
Interface Fe4 is connected to an ADSL router.
I have configure each interface with a default route and weighting:
ip route 0.0.0.0 0.0.0.0 Dialer0 200
ip route 0.0.0.0 0.0.0.0 FastEthernet 4 100
I need to configure Fe4 to get an address as a DHCP client:
interface FastEthernet4
ip address dhcp
no shut
duplex auto
speed auto
How do I remove Fe4 from VLAN1?
There is some existing config around VLAN 1:
interface Vlan1
ip address 10.73.0.1 255.255.255.0
ip helper-address 192.168.140.13
ip tcp adjust-mss 1400
no autostate
ip sla 100
icmp-echo 10.64.4.15 source-interface Vlan1
tag 3G Keepalive
frequency 10
Then I guess I need to adjust my Internet-IN ACL to allow broadcasts and UDP 67 and 68?
Brendon.
cadet alain
1st) you should do this:
no ip route 0.0.0.0 0.0.0.0 FastEthernet 4 100
ip route 0.0.0.0 0.0.0.0 x.x.x.x       where x.x.x.x is the IP address of the ADSL router
2nd) you should edit your internet-IN ACL to permit packets from the ADSL router( DHCP server) which are UDP packets with source port 67(bootpserver).
3rd) to remove f4 from vlan 1  ?? either it is a routed port already and so it is part of no vlan, either it is a switchport(L2 port)
and in which case you can either put it in another vlan and create the corresponding SVI  or make it a routed port(L3 port).
Regards.
Alain
