Cisco 881G SIM support
khader1977
Dear All,
I have scenario in which we need to connect 2 locations by 3G (data line) SIM card. Hence I am request you all to reply me whether we can use cisco 881G for this purpose?
Thaking you all in advqance for your valuable suggestions.
The router comes with Subscriber Identity Module (SIM) card: Universal Subscriber Identity Module (USIM) or Subscriber Identity Module (SIM) card slot on the PCI Express card (HSPA, UMTS, and GSM) on which you can inster your SIM card.
Please rate the helpfull posts.
Nadiu.
Latchum Naidu
You can absolutely use 3G SIM on 881G router.
Please see the below link for Initial configuration of a 881G router Cellular interface
http://inetpro.org/wiki/Initial_configuration_of_a_881G_router_Cellular_interface
Naidu.
Dear Naidu,
Thanks for the reply, I Have one more doubt the default modem comes wirth this router have SIM slot or we need to get other one to insert into the 3G slot.
Nadiu.
Dear Naidu,
Thanku very much for this great info.
