cisco 886va-w: snmp oids missing
macxylooly1
i miss some snmp oids on my cisco 886va-w for the following things:
bit swaps, crc and header errors on the vdsl side.
Here is a log file of the console output from the values i mean:
https://pastebin.com/Jqj5dzA4
Did anybody know the specific mib and oid?
CISCO-ADSL-DMT-LINE-MIB::cAdslAtucDmtConfBitSwapEnabled = No Such Instance currently exists at this OID
CISCO-ADSL-DMT-LINE-MIB::cAdslAtucDmtConfBitSwapFrom = No Such Instance currently exists at this OID
CISCO-ADSL-DMT-LINE-MIB::cAdslAtucDmtConfBitSwapTo = No Such Instance currently exists at this OID
This oids doesn't give me any value =(
The second thing is:
The output from the above link is not precise enough.
FECS for example, has only a summarized counter for different channels on this output.
You see that some values are only available for a specific channel (Downstream/Upstream 0/1).
But why are they not separated per channel? (Downstream/Upstream 0/1/2/3)
Is it possible to get more detailed information over snmp or any other way?
Kind Regards,
keglass
Level 7
Level 7
I am moving your question to the Routing space for better visibility and access to feedback from other users and Cisco experts.
Routing
Kelli Glass
Moderator for Cisco Customer Communities
