Unable to ping from BDI to router
bhaskar038
I'm trying to ping csr-1 to router. When router tries to ping, its sending ARP request and CSR is not responding. When CSR tries to ping, CSR is not even sending the ARP request.
The following is the configuration in CSR. Please let me know if I'm missing something.
int g 0
vrf forwarding mgmt-intf
no ip add
negotiation auto
service instance 10 ethernet
encapsulation 10 untagged
bridge domain 10
int bdi 10
mac-add 0aaa.0bbb.0ccc
ip add 10.10.10.10 255.255.255.0
Hi @bhaskar038
You are using vrf right? Are ping with vrf option on ping?
ping vrf vrf-name ip-address
-If I helped you somehow, please, rate it as useful.-
7 Replies 7
Hi @bhaskar038
Hi Miranda,
Thanks for your help. I simply changed from gig 0 (mgmt) to gig 1 and its working,
Hi Miranda,
I tested the same scenario by introducing Vlans.
On switch:
int f1/0
switch port mode access
switch port access vlan 10
int f1/1
switch port mode trunk
switch port trunk encapsulation dot1q
switch port trunk allowed vlan all
On CSR:
int g 2
no ip add
negotiation auto
no shut
encapsulation dot1q 10
bridge domain 10
int bdi 10
no shut
On router:
int f0/0
ip add 10.10.10.1 255.255.255.0
no shut
Unable to ping from router to CSR.
1) Unable to view the MAC address of the router in CSR arp table.
2) From wireshark, I can see that 10.10.10.1 is sending the ARP response but, CSR is not savin?
Only with this config I cant tell you what´s wrong.
Try to share the full config.
updated
@bhaskar038
Can you share the device config? If possible you can also share the GNS3 config file so that I can simulate the same scenarion on my machine. If the forum page does not allow you to attached the file, rename it with .txt extension and try again.
 Waiting for this information.
Hi Miranda,
The attached are the configs for switch and the router
I'm unable to find the saved config for CSR. But the attached are screenshots
Thanks for working on this!
