Cisco 887 va on UK VDSL no internet
tmx666
MFWS-ROUTER#show config
Using 2821 out of 262136 bytes
! Last configuration change at 17:01:04 BST Tue Jul 7 2020
version 15.3
hostname MFWS-ROUTER
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
aqm-register-fnf
enable secret 5 $1$9Yjw$iQdVvPXq0DcD.mCvdTrRP0
enable password
no aaa new-model
clock timezone London 0 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
ip dhcp excluded-address 10.0.0.1 10.0.0.5
ip dhcp pool MFWS
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
dns-server 10.0.0.113 8.8.8.8
domain-name MFWS.UK
lease 9
ip domain name mfws.uk
ip name-server 212.23.3.100
ip name-server 212.23.6.100
ip name-server 10.0.0.113
ip cef
no ipv6 cef
license udi pid C867VAE-K9 sn FCX9293Y09H
controller VDSL 0
modem UKfeature
interface Null0
no ip unreachables
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
ip nat outside
ip virtual-reassembly in
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 10.0.0.1 255.0.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Dialer0
description VDSL ZEN
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
ip route-cache policy
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
keepalive 30
ppp authentication chap callin
ppp chap hostname zen
ppp chap password 0
ppp direction callout
ppp ipcp address accept
no cdp enable
ip default-gateway 10.0.0.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source list 101 interface Ethernet0.101 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Ethernet0.101
ip access-list standard NAT
permit 10.0.0.0 0.0.0.255
access-list 1 permit 0.0.0.0 255.0.0.0
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
password
login
transport input all
scheduler allocate 20000 1000
end
Thats my config no internet access did work up until ios upgrade
Any ideas?
you need to add the below:
7 Replies 7
make the changes marked in bold:
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
enable password
no aaa new-model
ip dhcp pool MFWS
domain-name MFWS.UK
lease 9
ip cef
no ipv6 cef
controller VDSL 0
modem UKfeature
interface Null0
no ip unreachables
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
ip nat outside
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
keepalive 30
ppp chap password 0
no cdp enable
--> no ip default-gateway 10.0.0.1
no ip http server
--> no ip nat inside source list 101 interface Ethernet0.101 overload
--> no ip route 0.0.0.0 0.0.0.0 Ethernet0.101
--> no ip access-list standard NAT
--> access-list 1 permit 10.0.0.0 0.255.255.255
--> dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password
login
transport input all
end
Tried that you wrote still no internet access
post the running configuration again with the changes you have implemented...
Trying..
Connected
Escape character is '^]'.
User Access Verification
Password:
Password:
MFWS-ROUTER>enable
Password:
Using 2617 out of 262136 bytes
! Last configuration change at 18:42:52 BST Tue Jul 7 2020
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
enable password
no aaa new-model
ip dhcp pool MFWS
domain-name MFWS.UK
lease 9
ip cef
no ipv6 cef
license udi pid
controller VDSL 0
modem UKfeature
interface Null0
no ip unreachables
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
ip nat outside
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
keepalive 30
ppp chap password 0
no cdp enable
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password
login
transport input all
end
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
Password:
Password:
MFWS-ROUTER>enable
Password:
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
enable password
no aaa new-model
ip dhcp pool MFWS
domain-name MFWS.UK
lease 9
ip cef
no ipv6 cef
license udi pid
controller VDSL 0
modem UKfeature
interface Null0
no ip unreachables
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
ip nat outside
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
keepalive 30
ppp chap password 0
no cdp enable
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password
login
transport input all
end
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
MFWS-ROUTER#
How do i stop it showing telnet on the wan ip haha
Thabk you its its now up
