Cisco 887va - Allow Remote Access to a Web Server
John Adams
Hello.
I have a Cisco 887va which is connected to an ADSL line.
The internal network is a 192.168.1.x nework (255.255.255.0).
My WAN is a staticly assigned IP from the ISP - to save giving my actual IP I'll give an example 50.50.50.50
I have a webserver which serves https (tcp 443). This sits on 192.168.1.10. This has outbound internet through the Cisco.
I would like to make the https of the web server available externally, but only to 1 source IP (60.60.60.60).
How do I make this available?
My ISP have said I can use 50.50.60.61 - that is one of the IPs i'm allowed to use.
I'd like this as simple as possible. I don't have a firewall (cbac/zbf). Just standard ACLs for management access to my WAN for SSH.
I look forward to hearing from you.
John.
7 Replies 7
cadet alain
ip nat inside source static tcp 192.168.1.10 443 50.50.60.61 443
then  edit inbound ACL on WAN like this: this is an example so change with your real ACL number or name already applied inbound on WAN interface
ip access-list extended 100
10 permit tcp host 60.60.60.60 50.50.60.61 eq 443
Alain
Thanks Alain,
My existing access-lists look like this:
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 10 permit 60.60.60.60
access-list 10 permit 80.80.80.80
access-list 10 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
The access-list 10 is then used in 2 places. For the https access:
ip http access-class 10
and for the SSH access.
line vty 0 4
access-class 10 in
First of all - where does the NAT statement go? Anywhere specific in the config?
Then the ACL - I think I'd best create a new one?
Would it just be:
permit tcp host 60.60.60.60 50.50.60.61 eq 443 (This command didn't seem to enter correclty for me have i missed something?).
Then for an additional source IP i'd do:
permit tcp host 80.80.80.80 50.50.60.61 eq 443
I'd rather not edit my original ACLs if possible.
Thanks.
ok if your only ACL is used in access-class then indeed you need a newer ACL to apply inbound on the WAN interface.
access-list 100 permit tcp host 60.60.60.60 host 50.50.50.61 eq 443
access-list 100 deny tcp any host 50.50.50.61 eq 443
access-list 100 permit ip any any
int x/x <<<<< your WAN interface
ip access-group 100 in
For the static  PAT you enter it in global config
Alain
Thank you. I have added the ip access-group 100 in under my interface Dialer0 (ADSL connection).
I will test and let you know. Is there any troubleshooting I can do to see why it is not hitting an ACL, if the router is listening correctly on the IP, etc?
Thank you.
you could enable logging on the ACL while testing it and for NAT you can look at sh ip nat translation.
this is not the securest config but as you asked not to use any firewalling feature, now we could edit the ACL to make it less permissive if you want to  like this:
10 permit icmp any any echo-reply
11 permit udp any eq domain  any
31 deny ip any any log
in ACE 11 replace the first any by host x.x.x.x where x.x.x.x is your  external DNS server
Alain
Thanks Alain,
Can I just check this looks right:
What I want to achieve.
Keep my Management acces (SSH) with access-list 10. Deny anything else other than a remote IP of 70.70.70.70 for SSH access. It should only have ssh and no other ports.
Allow one remote IP (60.60.60.60) through to my web server (192.168.1.10 via the ext IP of 50.50.50.61).
Nothing else should be allowed access to the web server on 443.
Nothing else should be allowed access to anything from external.
Interface Dialer0
ip nat inside source static tcp 192.168.1.10 443 50.50.50.61 443 extendable
access-list 10 permit 70.70.70.70
line vty 0 4
access-class 10 in
Given the fact that you don't want to use firewall or reflexive ACL, I would say that it pretty does the job you are asking for, except that everyone will be able to ping or traceroute to your external IP.
Alain
