Auto Copp Policy
I have to install two new cisco 6509 with Sup 2T 10G modules.
Now there is a small problem in configuration which is there by default.
It is not getting erased..can anyone help???
I am mentioning below the configuration which I'll have to remove.
I already used the command
"no service-policy input policy-default-autocopp", but upon erasing class map and policy map and then rebooting the unit again same configuration appears.
class-map match-any class-copp-icmp-redirect-unreachable
class-map match-all class-copp-glean
class-map match-all class-copp-receive
class-map match-all class-copp-options
class-map match-all class-copp-broadcast
class-map match-all class-copp-mcast-acl-bridged
class-map match-all class-copp-slb
class-map match-all class-copp-mtu-fail
class-map match-all class-copp-ttl-fail
class-map match-all class-copp-arp-snooping
class-map match-any class-copp-mcast-copy
class-map match-any class-copp-ip-connected
class-map match-any class-copp-match-igmp
  match access-group name acl-copp-match-igmp
class-map match-all class-copp-unknown-protocol
class-map match-any class-copp-vacl-log
class-map match-all class-copp-mcast-ipv6-control
class-map match-any class-copp-match-pimv6-data
  match access-group name acl-copp-match-pimv6-data
class-map match-any class-copp-mcast-punt
class-map match-all class-copp-unsupp-rewrite
class-map match-all class-copp-ucast-egress-acl-bridged
class-map match-all class-copp-ip-admission
class-map match-all class-copp-service-insertion
class-map match-all class-copp-mac-pbf
class-map match-any class-copp-match-mld
  match access-group name acl-copp-match-mld
class-map match-all class-copp-ucast-ingress-acl-bridged
class-map match-all class-copp-dhcp-snooping
class-map match-all class-copp-wccp
class-map match-all class-copp-nd
class-map match-any class-copp-ipv6-connected
class-map match-all class-copp-mcast-rpf-fail
class-map match-any class-copp-ucast-rpf-fail
class-map match-all class-copp-mcast-ip-control
class-map match-any class-copp-match-pim-data
  match access-group name acl-copp-match-pim-data
class-map match-any class-copp-match-ndv6
  match access-group name acl-copp-match-ndv6
class-map match-any class-copp-mcast-v4-data-on-routedPort
class-map match-any class-copp-mcast-v6-data-on-routedPort
policy-map policy-default-autocopp
  class class-copp-mcast-v4-data-on-routedPort
   police rate 10 pps burst 1 packets    conform-action drop     exceed-action drop
  class class-copp-mcast-v6-data-on-routedPort
  class class-copp-match-mld
   police rate 10000 pps burst 10000 packets    conform-action set-discard-class-transmit 48    exceed-action transmit
  class class-copp-match-igmp
  class class-copp-icmp-redirect-unreachable
   police rate 100 pps burst 10 packets    conform-action transmit     exceed-action drop
  class class-copp-ucast-rpf-fail
  class class-copp-vacl-log
   police rate 2000 pps burst 1 packets    conform-action transmit     exceed-action drop
  class class-copp-mcast-punt
   police rate 1000 pps burst 256 packets    conform-action transmit     exceed-action drop
  class class-copp-mcast-copy
  class class-copp-ip-connected
  class class-copp-ipv6-connected
  class class-copp-match-pim-data
   police rate 1000 pps burst 1000 packets    conform-action transmit     exceed-action drop
  class class-copp-match-pimv6-data
  class class-copp-match-ndv6
   police rate 1000 pps burst 1000 packets    conform-action set-discard-class-transmit 48    exceed-action drop
ip access-list extended acl-copp-match-igmp
permit igmp any any
ip access-list extended acl-copp-match-pim-data
deny   pim any host 224.0.0.13
permit pim any any
ipv6 access-list acl-copp-match-mld
permit icmp any any mld-report
permit icmp any any mld-query
permit icmp any any mld-reduction
permit icmp any any 143
ipv6 access-list acl-copp-match-ndv6
permit icmp any any nd-na
permit icmp any any nd-ns
permit icmp any any router-advertisement
permit icmp any any router-solicitation
permit icmp any any redirect
ipv6 access-list acl-copp-match-pimv6-data
deny 103 any host FF02::D
permit 103 any any
control-plane
John Blakley
Try going into the control-plane first, remove it from there and then you should be able to remove it from the config. Don't forget to save changes before reloading the switch...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Ivan Shirshin
It is intended to work like this.  If the policy map itself is removed, it will be recreated at the time of reload and it will be tried to apply on the copp interface, as it is default configuration for the CoPP.
If you want to remove the control plane policy, better remove it from the control-plane interface using "no service-policy <> <>". Save the config after removing the service policy from the interface and reload, the should not be seen.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Ivan
I removed it from the control plane interface and its getting removed alsot. After the rebooting of swithc its also not showing under control plane, but class map and policy maps are still there. Then again if I am removing the class maps and policy maps, and rebooting the switch, again the complete config appears itself.
R's
Manjeet
stmsystems
All these default copp entries are polluting my basic config on a Nexus 3048.  It seems I'm unable to remove this:
(config)# control-plane
(config-cp)# no service-policy input copp-system-policy
% Invalid command at '^' marker.
Is the documentation for this switch model hinting that this is impossible to hide?  Does it not make sense to hide defaults unless they have been overriden?
