Cisco 887VA booting issue with static NAT
the_maxtor
Hi all,
i have a strange issue with a Cisco 887va-k9.
I configured an ATM point to point sub interface, an interface vlan for LAN use with private address, an overload NAT to give internet access to LAN and a port forwarding to access to a web server from internet.
All work until the router restart, during reload it stop at the choose config file step.
If i remove the port forwarding command, the router reboot without problem.
Any idea/advice?
This is the config:
version 15.6
hostname name
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
ethernet lmi ce
ip domain name dominio
ip name-server 151.99.125.2
ip name-server 151.99.250.2
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ220190RS
username admin secret 5
controller VDSL 0
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address X.X.X.54 255.255.255.252
ip nat outside
ip virtual-reassembly in
pvc 8/35
oam-pvc manage
oam retry 5 5 1
encapsulation aal5snap
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
switchport access vlan 10
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
interface Vlan10
description management
ip address 192.168.200.14 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool PUBLIC Y.Y.Y.70 Y.Y.Y.70 netmask 255.255.255.252
ip nat inside source list 101 pool PUBLIC overload
ip nat inside source static tcp 192.168.1.200 554 Y.Y.Y.70 554 extendable
ip nat inside source static tcp 192.168.1.201 2000 Y.Y.Y.70 2000 extendable
ip nat inside source static tcp 192.168.1.201 2001 Y.Y.Y.70 2001 extendable
ip nat inside source static tcp 192.168.1.200 8000 Y.Y.Y.70 8000 extendable
ip nat inside source static tcp 192.168.1.200 8080 Y.Y.Y.70 8080 extendable
ip route 0.0.0.0 0.0.0.0 X.X.X.53
ip route 192.168.0.0 255.255.0.0 192.168.200.1
ip ssh version 2
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input all
transport output all
line vty 5 15
login local
transport input all
scheduler allocate 20000 1000
end
you might be hitting the bug below:
Router getting hang after reload when using static NAT
CSCve86017
Description
$$IGNORE
Router C887VA-K9 is not coming up after reload, while below static nat configuration command is present in startup-config.
ip nat inside source static tcp x.x.x.x yyyy x.x.x.x yyyy extendable
Device is completing boot process and getting hang. To get the device back, need to pass the startup-config from rommon mode.
Symptom:
Router is getting hang after reload when using static NAT configuration line as below:
ip nat inside source static tcp 192.168.1.150 3389 80.19.214.181 3389 extendable
Conditions:
Below static NAT configuration line saved in startup-config
Workaround:
Use dynamic rule or static rule without specific tcp/udp entry rule as of now.
Known Fixed Releases: (5)
15.7(3.1.14A)OT
15.7(3.1.8A)OT
15.7(3.1.6R)OT
15.7(3.0c)M
15.7(3)M1
5 Replies 5
Hello
Not so sure i understand, you reloaded your router and it failed to boot up correctly due to a port forwarding command?
As for your NAT configuration
I see your nat statements but dont see any access-list 101 which is specified and vlan 10 doesn't have nat applied to it either.
res
Paul
Kind Regards
Paul
Hi Paul,
you perfectly understand the situation.
Vlan10 doesn't need any kind of NAT, it's used only to manage the router.
Access list 101 is the following:
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
If i remove the following commands the router reload correctly:
If those commands is in the startup config, the router doesn't complete the boot and all the led are off, except the OK led that is fixed green.
CSCve86017
Description
$$IGNORE
Symptom:
Conditions:
Workaround:
15.7(3.1.14A)OT
15.7(3.1.8A)OT
15.7(3.1.6R)OT
15.7(3.0c)M
15.7(3)M1
What a wonderful bug. Who use static NAT in this world?
Anyway thanks Georg.
As soon as i receive a firmware with the fix, i'll try and i'll let you know
Hi all,
with the update of IOS the bug is fixed.
I installed IOS 15.7(3)M1, that is one of the known release with the specific fix.
Now i can reboot my Cisco 887VA-K9, with static NAT configuration, without any problem.
Thanks all for the help.
