Cisco 888 router clients internet access problem
kubilaytr06
Hi All,
I have a Cisco 888 router that is connected to a 8 port  non-cisco switch. I have WAN/DHCP configured on the router and the switch is non smart and programmable..
The issus that none of the client machines can access the Internet.They can take an ip from router but doesn t have internet.I try to ping 8.8.8.8 etc but doesn t work. From within the router console, I am able to ping external domain names, my ISP DNS servers.We have static ip from the ISP
Client machines can ping the Cisco router IP.
I have checked google looking for an answer on why, but I am missing something I just don't know why. Any help would be helpful.
Here is the config
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool akk
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 195.175.39.39 195.175.39.40
   lease 0 1 50
ip cef
ip name-server 195.175.39.39
ip name-server 195.175.39.40
no ipv6 cef
license udi pid CISCO888-K9 sn FCZ1516C02R
username xx privilege 15 password 0 cisco
controller DSL 0
mode atm
dsl-mode shdsl symmetric annex B
line-rate 2048
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
interface ATM0.1 point-to-point
ip address 88.222.222.22 255.255.255.248
atm route-bridged ip
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSID
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username aaaa@net password 0 1111
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 remark INSIDE_IF=vlan1
access-list 1 remark CCP_ACL category=2
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
Giuseppe Larosa
Hello Kubilay,
if you access the internet using ATM0.1 subinterface you need to change your NAT statement in :
ip nat inside source list 1 interface ATM0.1 overload
interface ATM0.1
ip nat outside
but you would need also a default  static route using ATM0.1 instead of dialer0
ip route 0.0.0.0 0.0.0.0 ATM0.1
it is not clear.How do you access the internet?
with PPPoE over ATM on pvc8/35 or by using subinterface ATM0.1?
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello Kubilay,
interface ATM0.1
ip nat outside
Hope to help
Giuseppe
Hello Giuseppe,
Thanks for your replay.Actualy  I'm not sure about whichone we are using for access internet.ISP sent a examp. config for me and i applied it to us.I'll try your suggest and replay back.
Thank you
Thank you soo much Dear Giuseppe..
Best Wishes
Hello Kubilay,
thanks for rating, just for information your internet access is via the ATM0.1 subinterface?
Because the changes i have proposed were done under this hyphotesis starting from your note about static IP address from ISP.
Best Regards
Giuseppe
Dear Giuseppe,
yess our internet access is via ATM0.1 subinterface.And i added your suggested ip nat as"ip nat inside source list 101 interface Dialer0 overload".After that everyhthing working fine.
Hello I have got the same router and I am trying to connect it to a non CISCO modem but I don't know how because it is not a standard 800 series configuration configuration.
