Cisco 891 and IP SLA
gerardhunt
I have recently taken a oposition with a firm where the existing infrastructure has just been installed by a third-party.
A Cisco 891 has been intalled with IP SLA configured to provide failover to a secondary ISP link.
Within days of my arrival the 891 stoped routing to either WAN interface serval times a week. When this would happen it was possible to to Ping both WAN devices connected to the router from inside and outside, but not possible to ping past them in ether direction.
My immediate suspicions were that the IP SLAs were incorrectly configured. I have disabled them and have not ecperienced any problems since. But I am concerned as to why they were causing the device to stop routing.
If any one fancies taking a look below and making suggestions please go ahead.
For security some details have been altered for this exercise. The relevant sections are in bold
Current configuration : 6797 bytes
version 12.4
hostname XXXX001
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 52000
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone AEST 10
clock summer-time AEDT recurring 1 Sun Oct 2:00 1 Sun Apr 3:00
crypto pki trustpoint TP-self-signed-xxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxx
revocation-check none
rsakeypair TP-self-signed-4057743359
crypto pki certificate chain TP-self-signed-xxx
certificate self-signed 01
! Lines removed for security
   quit
no ip source-route
ip cef
no ip bootp server
ip domain name xxx.com
no ipv6 cef
vpdn enable
no spanning-tree vlan 1
no spanning-tree vlan 2
username xxxxx privilege 15 secret 5 xxxx
archive
log config
  hidekeys
track 1 ip sla 1 reachability
delay down 10 up 10
track 2 ip sla 2 reachability
delay down 10 up 10
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
ip address xxx.yyy.13.214 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
description ***2M / 2M SHDSL***
ip address xxx.yyy.13.118 255.255.255.252
ip flow ingress
ip nat outside
duplex full
speed auto
interface Vlan1
description ***LAN***
ip address 192.168.120.253 255.255.255.0
ip access-group 120 in
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxx.yyy.13.213 240 track 1
ip route 0.0.0.0 0.0.0.0 xxx.yyy.13.117 250 track 2
ip route 192.1.1.0 255.255.255.0 192.168.120.254
ip route 192.168.121.0 255.255.255.0 192.168.120.254
no ip http server
ip http access-class 50
ip http authentication local
ip http secure-server
ip http secure-port 50443
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip flow-top-talkers
top 10
sort-by bytes
ip dns server
ip nat inside source route-map NAT1 interface FastEthernet8 overload
ip nat inside source route-map NAT2 interface GigabitEthernet0 overload
ip nat inside source static tcp 192.168.120.41 25 xxx.yyy.13.118 25 route-map NAT2 extendable
ip nat inside source static tcp 192.168.120.41 80 xxx.yyy.13.118 80 route-map NAT2 extendable
ip nat inside source static tcp 192.168.120.41 443 xxx.yyy.13.118 443 route-map NAT2 extendable
ip nat inside source static tcp 192.1.1.2 1723 xxx.yyy.13.118 1723 extendable
ip nat inside source static tcp 192.168.120.47 3389 xxx.yyy.13.118 3389 route-map NAT2 extendable
ip nat inside source static tcp 192.168.120.41 25 xxx.yyy.13.214 25 route-map NAT1 extendable
ip nat inside source static tcp 192.168.120.41 80 xxx.yyy.13.214 80 route-map NAT1 extendable
ip nat inside source static tcp 192.168.120.41 443 xxx.yyy.13.214 443 route-map NAT1 extendable
ip nat inside source static tcp 192.1.1.2 1723 xxx.yyy.13.214 1723 extendable
ip nat inside source static tcp 192.1.1.203 3389 xxx.yyy.13.214 3389 route-map NAT1 extendable
ip access-list extended VPN_ADDRESS
permit ip 192.168.120.0 0.0.0.255 192.168.192.0 0.0.0.255
ip sla 1
icmp-echo xxx.yyy.13.213 source-ip xxx.yyy.13.214
timeout 1000
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo xxx.yyy.13.117 source-ip xxx.yyy.13.118
timeout 1000
frequency 5
ip sla schedule 2 life forever start-time now
access-list 50 remark ***RemoteAccess***
access-list 50 permit 210.185.92.41
access-list 50 permit 121.212.238.53
access-list 50 permit 192.168.0.0 0.0.255.255
access-list 50 permit 192.1.1.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
access-list 101 permit ip 192.1.1.0 0.0.0.255 any
access-list 120 permit tcp host 192.1.1.31 any eq smtp
access-list 120 permit tcp host 192.1.1.32 any eq smtp
access-list 120 permit tcp host 192.168.120.41 any eq smtp
access-list 120 deny   tcp 192.1.1.0 0.0.0.255 any eq smtp
access-list 120 deny   tcp 192.168.120.0 0.0.0.255 any eq smtp
access-list 120 deny   tcp 192.168.121.0 0.0.0.255 any eq smtp
access-list 120 permit ip any any
snmp-server community xxx RO 50
snmp-server location xxxxxxxxxx
no cdp run
route-map NAT2 permit 10
match ip address 101
match interface GigabitEthernet0
route-map NAT1 permit 10
match interface FastEthernet8
control-plane
privilege exec level 15 configure
line con 0
timeout login response 300
privilege level 15
logging synchronous
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 50 in
privilege level 15
logging synchronous
transport input ssh
line vty 5 193
access-class 50 in
privilege level 15
logging synchronous
transport input ssh
scheduler max-task-time 5000
ntp server 192.231.203.132
ntp server 192.189.54.17
ntp server 192.189.54.33
end
Gregory Camp
Do you have the logs from the time of the outage?  Did the IP SLAs fail during the outage?
The logs are very bland. There are only two statements in it of relevance
IPA SLA 1 Reachability up ->down
IPA SLA 2 Reachability up ->down
So the SLA works in so far that a perfomance/connection issue on the primary WAN feed forces a failover to the secondard WAN feed.
However, it does not fail back. Then when the secondary WAN feed fails on a performance/connection issue, it too fails.
Result, no routing.
I am not concerned about what triggers the SLA. That is not a problem.  But why the SLA doesnt fail-back does concern me.
I am misisng something in the config.
Gerard,
I do not believe you are missing anything in the configuration.  IP SLA should continue to send ICMP echo requests forever as soon as the router finishes loading.  Even if the track goes down, the IP SLA process should continue.  Are the IP SLAs currently in a filed state?  If so, please grab the output of show ip sla stat and show track.
Greg
