Cisco 899 4G module data roaming
antar
Storry if this has been posted before. I've been googling his for quite some time now. Does anyone know how to disable data roaming on the Cellular interface of this router? Is it even possible?
try the command:
no cellular x lte plmn search
I am not sure if it is enabled by default. The result should be that roaming is disabled, you can verify that with:
899#show cellular 0 network
Current System Time = Tue Jan 30 10:39:24 2018
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Roaming
Doesn't recognize command.
I'm running (C800-UNIVERSALK9-M), Version 15.5(3)M5, RELEASE SOFTWARE (fc1).
I've disabled auto network search and manually selected the mobile provider I use.
Maybe that's enough. IDK
