GRE Issues
sprocket10
Level 2
Level 2
GRE was running across 2 Linux systems between sites. The VPN was between an ASA and WatchGuard with no issues. Recently we replaced the WatchGuard with an ASA, and the GRE tunnel is now only working in one direction. I have compared both ASAs and cant spot an obvious issue.
Deepak Kumar
Then you have to check your routing and ACL configuration for the GRE tunnel.
For more investigation please share running configuration of both ASA.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Julio E. Moisa
Check the ACLs to know if they have the same permissions.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
