Cisco Access Server 2509 IOS Corrupt
maninthemirrow
hello Guys,
l have cisco access server 2509 and for some reason l think the IOS is corrupt. l try but cannot get in. someone help how to re-installed the IOS again please
thanks
7 Replies 7
Hi ,
 This product is no longer supported . If you have IOS image with you , upload it from Rommon mode
http://www.cisco.com/c/en/us/support/docs/routers/2500-series-routers/15078-recovery-c2500.html
Sandy
thanks
if l turn it on with the rollover cable connected to the pc. it display zigzag characters
and it has not got the button like switch to hold till it takes you to the rommon command line.
From the Using the ROMmon confreg Utility example above, you see that there are eight possible console baud rates, namely, 9600 (default), 4800, 1200, 2400, 19200, 38400, 57600, and 115200 baud. If you do not know the console speed of the router, it is difficult to set up a hyperterminal session with the correct speed. A solution would be to just try the eight possible console speeds above and see which one works. Another solution would be to open up the box and move a jumper.
Sandy
hello Sandy
can you see the image of console. so l cannot get into the IOS at all
any idea please
salis
Hi ,
  Have you got access to console , after changing BAUD rate Speed .
Sandy
hello
when l connect the console to the pc. that is what l see.l am using tera terms, l cannot get into the console even lf l try to issue the break after turning the device on
hello mr Sandy
l have attach an image of what l see
