Cisco Analog VoIP
Hello friends,
we have a router 3945 with the following modules -
Our idea is this - someone is calling a mobile number for example +3598212312 The person is connecting to the number but after that the number redirects the call to the Cisco 3945 then the router calls an ip phone inside it. The point is i think we need additional modules like
http://www.ebay.it/itm/Cisco-VIC-2FXS-2-port-Voice-Card-2600-2600XM-3600-3700-/140335501979?pt=US_Enterprise_Router_Modules_Cards_Adapters&hash=item20aca5d29b&_uhb=1
or
http://www.ebay.it/itm/Cisco-VIC-2FXO-2-port-Voice-Card-2600-2600XM-3600-3700-/110417554561?pt=US_Enterprise_Router_Modules_Cards_Adapters&hash=item19b5662c81&_uhb=1
am i right and what is the correct module we need. and if i am right how should the connection look like. And what about the router redirecting config? Thanks a lot
5 Replies 5
ageralde
Hi svetoslavsimeonov,
Aside from the Cisco 3945, do you also have an existing application in your router such as the Call manager or Unified Communications?You need to have the compatible voice interface card for the 3945 to enable the voice feature.  Feel free to message me directly for further discussion on this.
Angela (ageralde@cisco.com)
Hello Ageralde,
do you ask for Cisco Unified Communication Manager Express if yes - the answer is "yes" we have. Are the cards i have posted before the right FXO or not?
Thanks!
Thank you for the response. Yes, the cards are also FXO but you may want to look if they are compatible with the 3900 ISR. Please check this link for the compatible voice interface cards for  the ISR 3900 (http://cs.co/9008cqvQ).
Sorry friend, can you give me an example fxo vic from ebay that is compatible with cisco 3945 router? Thanks a lot!
Please check the link for the compatible voice interface cards for the ISR 3945 (http://cs.co/9004cCpk) . You may also email me directly for further assistance for the part number that you will be looking at buying.
