cisco and juniper
bogdan.bugher
Hi there,
I have an juniper ssg5 and I need an cisco to be able to establish an vpn conection with juniper via ipsec vpn. What model from cisco do you recomend? I am interesting for an chipper equipment, maybe smb series.
Manny thanks and kind regards,
7 Replies 7
Bilal Nawaz
What is the budget?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
closer to 100$
I dont know much about SMB routers but the RV180 seems OK, how many ports do you need?
You can see some selection here: http://www.cisco.com/c/en/us/products/routers/small-business-rv-series-routers/models-comparison.html
http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/index.html-tab-Routers?POSITION=LINK&COUNTRY_SITE=us&CAMPAIGN=SMB+Samba&CREATIVE=ESCAPE+HATCH&TIS=__0240_&REFERRING_SITE=CISCO.COM+ROUTERS
Just do a quick google for the estimated price. Also don't discount other vendors like Juniper - maybe the SRX100 will be good for you.
Ok, I've installed an RV130, I've configured the ipsec siste to site VPN, the tunnel apears to be up but I have no comunication to the other site. It looks like it doesn't have a route established. What is wrong? What am I missing?
Since we do not know what you have configured it is not possible for us to identify what you have missed. I started to ask that you post the configuration but then realize that this router has a GUI interface. If you back up the config does it produce a text file that is readable? If so that might help us understand what you have configured which would then perhaps help us identify what the problem is.
Rick
Rick
;RV130 Configuration File - Version: 1.0.1.3
;MAC address: xx:xx:xx:xx:xx:xx
;Serial Number: xxxxxxxxxxxxx
;The checksum: xxxxxxxxxxxxxxxxx
(null)_corerev=
(null)_hwaddr=
(null)_ifname=
(null)_phytype=g
(null)_phytypes=
(null)_radio=1
(null)_radioids=
6to4_ifname=sit1
access_point_enable=0
add_static_route=
admin_timeout=30
aging=180
aging_time_true=0
ap_ipv6_dhcpc_pd=0
ap_mode=0
ap_mtu_enable=0
ap_old_vlan_group=1
ap_wan_dns=208.67.222.222 208.67.220.220
ap_wan_dns_mode=0
ap_wan_gateway=0.0.0.0
ap_wan_ip_mode=3
ap_wan_ipaddr=192.168.1.245
ap_wan_ipv6_dns_primary=
ap_wan_ipv6_dns_secondary=
ap_wan_ipv6_gateway=
ap_wan_ipv6_ipaddr=
ap_wan_ipv6_prefixlen=0
ap_wan_ipv6_proto=dhcp
ap_wan_mgt_vlan_id=1
ap_wan_mtu=1500
ap_wan_netmask=255.255.255.0
ap_wan_primary_dns=0.0.0.0
ap_wan_proto=static
ap_wan_secondary_dns=0.0.0.0
ap_wan_static_dns_mode=1
ap_wan_untag_vlan_enable=1
ap_wan_untag_vlan_id=1
auth_ip=5.14.144.96
autofw_port0=
block_activex=0
block_cookie=0
block_java=0
block_loopback=0
block_proxy=0
block_wan=0
bonjour_enable=on
bonjour_vlan=1
bsd_action=0
bsd_admin_enable=0
bsd_crelver=1.0.1.1
bsd_interval=week
bsd_logmail_enable=0
bsd_mail_enable=0
bsd_orelver=1.1.0.5
bsd_random_str=44
bsd_sel_time=2
bss_enabled=0
certinEEPROM=
certinjffs2=
closed=1
cybertan_u-boot_ver=1.0.1.3
daylight_enable=0
daylight_time=0
ddns_cache_1=
ddns_change=
ddns_enable_1=0
ddns_enable_2=0
ddns_enable_3=0
ddns_enable_4=0
ddns_enable_buf=
ddns_hostname_1=
ddns_hostname_2=
ddns_hostname_3=
ddns_hostname_4=
ddns_hostname_buf=
ddns_interval=60
ddns_passwd_1=
ddns_passwd_2=
ddns_passwd_3=
ddns_passwd_4=
ddns_passwd_buf=
ddns_service_1=
ddns_service_2=dyndns
ddns_service_3=
ddns_service_4=
ddns_status_1=
ddns_update_4=0
ddns_username_1=
ddns_username_2=
ddns_username_3=
ddns_username_4=
ddns_username_buf=
def_hwaddr=00:00:00:00:00:00
default_lang=0
default_login=1
del_one2one_cnt=0
del_static_route=
dev_pid_short=RV130
dhcp1_end=192.168.2.150
dhcp1_start=192.168.2.100
dhcp_domain=wan
dhcp_lease=1440
dhcp_lease_1=1440
dhcp_num=50
dhcp_num_1=50
dhcp_start=100
dhcp_start_1=100
dhcp_statics=
dhcp_statics_1=
dhcp_wins=wan
dhcrelay_ipaddr=0.0.0.0
dhcrelay_ipaddr_1=0.0.0.0
dmz_enable=0
dmz_ipaddr=0
dos_protection=0
dr_lan_rx=2
dr_lan_tx=2
dr_setting=0
dr_wan_rx=2
dr_wan_tx=2
dst_mode=0
email_alert_cpu=0
email_alert_enable=1
email_alert_firewall=0
email_alert_system=0
email_alert_vpn=1
email_alert_wan=0
en_aging=1
en_pwd=0
en_pwddiff=1
et_dispatch_mode=1
et_pwrsave=0
filter=off
filter_client0=
filter_dport_grp10=
filter_dport_grp1=
filter_dport_grp2=
filter_dport_grp3=
filter_dport_grp4=
filter_dport_grp5=
filter_dport_grp6=
filter_dport_grp7=
filter_dport_grp8=
filter_dport_grp9=
filter_id=1
filter_ip_grp10=
filter_ip_grp1=
filter_ip_grp2=
filter_ip_grp3=
filter_ip_grp4=
filter_ip_grp5=
filter_ip_grp6=
filter_ip_grp7=
filter_ip_grp8=
filter_ip_grp9=
filter_mac_grp10=
filter_mac_grp1=
filter_mac_grp2=
filter_mac_grp3=
filter_mac_grp4=
filter_mac_grp5=
filter_mac_grp6=
filter_mac_grp7=
filter_mac_grp8=
filter_mac_grp9=
filter_maclist=
filter_macmode=deny
filter_port=
filter_port_grp10=
filter_port_grp1=
filter_port_grp2=
filter_port_grp3=
filter_port_grp4=
filter_port_grp5=
filter_port_grp6=
filter_port_grp7=
filter_port_grp8=
filter_port_grp9=
filter_rule10=
filter_rule1=
filter_rule2=
filter_rule3=
filter_rule4=
filter_rule5=
filter_rule6=
filter_rule7=
filter_rule8=
filter_rule9=
filter_tod10=
filter_tod1=
filter_tod2=
filter_tod3=
filter_tod4=
filter_tod5=
filter_tod6=
filter_tod7=
filter_tod8=
filter_tod9=
filter_tod_buf10=
filter_tod_buf1=
filter_tod_buf2=
filter_tod_buf3=
filter_tod_buf4=
filter_tod_buf5=
filter_tod_buf6=
filter_tod_buf7=
filter_tod_buf8=
filter_tod_buf9=
filter_web_host10=
filter_web_host1=
filter_web_host2=
filter_web_host3=
filter_web_host4=
filter_web_host5=
filter_web_host6=
filter_web_host7=
filter_web_host8=
filter_web_host9=
filter_web_url10=
filter_web_url1=
filter_web_url2=
filter_web_url3=
filter_web_url4=
filter_web_url5=
filter_web_url6=
filter_web_url7=
filter_web_url8=
filter_web_url9=
first_login=0
force_non_querier=0
forward_port=
forward_portrange0=
forward_portrange10=
forward_portrange11=
forward_portrange12=
forward_portrange13=
forward_portrange14=
forward_portrange15=
forward_portrange16=
forward_portrange17=
forward_portrange18=
forward_portrange19=
forward_portrange1=
forward_portrange2=
forward_portrange3=
forward_portrange4=
forward_portrange5=
forward_portrange6=
forward_portrange7=
forward_portrange8=
forward_portrange9=
forward_portsip=
forward_single0=80,80,tcp, ,off,HTTP
forward_single10=2401,2401,tcp, ,off,CVS
forward_single11=2701,2701,tcp, ,off,SMS
forward_single12=2702,2702,tcp, ,off,SMS-rmctl
forward_single13=
forward_single14=
forward_single15=
forward_single16=
forward_single17=
forward_single18=
forward_single19=
forward_single1=21,21,tcp, ,off,FTP
forward_single2=23,23,tcp, ,off,Telnet
forward_single3=25,25,tcp, ,off,SMTP
forward_single4=69,69,udp, ,off,TFTP
forward_single5=79,79,tcp, ,off,finger
forward_single6=123,123,udp, ,off,NTP
forward_single7=110,110,tcp, ,off,POP3
forward_single8=119,119,tcp, ,off,NNTP
forward_single9=161,161,udp, ,off,SNMP
fresh_rate_auth=15
fresh_rate_vpn=15
fw_acl_01=1,0,1,1,1,0,0,1,11,192.168.3.1,192.168.3.254,192.168.0.1,192.168.0.254,0,0,0,All Traffic
fw_acl_02=1,1,0,1,0,0,0,1,11,192.168.0.0,192.168.0.254,192.168.3.100,0,0,0,0,All Traffic
fw_acl_cnt=1
fw_acl_def_policy=1
fw_disable=0
get_country=EU
getting_start=1
getting_wizard=0
gn_0_enable=0
gn_1_enable=0
gn_2_enable=0
gn_3_enable=0
gn_agree_title_0=Check here to indicate that you have read and accepted Use Policy.
gn_bg_0=
gn_company_title_0=Small Business
gn_copyright_title_0=© 2014 Cisco Sytems, Inc. All rights reserved.
gn_declaration_enable_0=0
gn_enable=0
gn_error_1_title_0=Login failed. Incorrect username or password.
gn_error_2_title_0=All connections are currently in use, please try again a little later.
gn_font_color_0=white
gn_login_title_0=Log In
gn_logo_0=
gn_password_title_0=Password
gn_profile_name_0=Default_Portal_Profile
gn_redirect_url_0=
gn_redirect_url_enable_0=0
gn_session_time_0=0
gn_username_title_0=Username
gn_verification_0=0
gn_welcome_title_0=Tomorrow Starts Here
guest_aging_time_true=0
guest_timeout=30
http_enable=0
http_from=wan
http_lanport=80
http_method=post
http_passwd=admin
http_power=rw
http_user0=rw,enc=7ac4287f2b4fb648c39951ea26f6192d,cisco
http_user1=r,enc=2f7ff934e162e076bd48052a7e3ad95a,guest
http_user_count=2
http_username=
http_wanport=443
https_cert=
https_enable=1
https_key=
ident_pass=0
igmp_proxy_channel=NULL
igmp_proxy_type=NULL
igmp_version=0
ike_using_index=1
immediate_leave_enable=0
inter_route=1
ip_conntrack_max=18432
ip_conntrack_tcp_timeout_established=600
ipsec_DPD_delay_1=
ipsec_DPD_timeout_1=
ipsec_alarmentry_1_descr=
ipsec_auth_mode_1=
ipsec_auth_psk_1=
ipsec_debug=1
ipsec_enabled_1=
ipsec_key_renegotiation_1=
ipsec_local_ipaddr_1=
ipsec_local_mask_1=
ipsec_natt=0
ipsec_netonet_entry=
ipsec_pass=1
ipsec_peer_reauth_time_1=
ipsec_remote_gw_1=
ipsec_remote_ipaddr_1=
ipsec_remote_mask_1=
ipsec_using_index=1
ipv6_4to6_localip=
ipv6_4to6_remoteip=
ipv6_4to6en=0
ipv6_6rd_delegated_prefix=
ipv6_6rd_delegated_prefixlen=
ipv6_6rd_mode=0
ipv6_6rd_prefix=
ipv6_6rd_prefix_len=
ipv6_6rd_relay=
ipv6_6rd_v4mask_len=
ipv6_6to4_autoen=1
ipv6_6to4_mode=6to4
ipv6_6to4_remoteip=0.0.0.0
ipv6_delegate_en=0
ipv6_dhcpc_pd=1
ipv6_dhcpc_pd_prefix=
ipv6_dhcpc_pd_prefixlen=0
ipv6_dhcps_pd=0
ipv6_dhcps_pd_prefix_end=
ipv6_dhcps_pd_prefix_len=64
ipv6_dhcps_pd_prefix_start=
ipv6_isatap_prefix=
ipv6_isatap_prefix_len=64
ipv6_pppoe_addr_mode=dhcp
ipv6_ready_logo_lan_sleep_time=0
ipv6_tunnel_ifname=ip6tun
l2tp_dhcp=0
l2tp_get_ip=
l2tp_pass=1
l2tp_server_ip=
l2tp_version=2
l2tpv3_auth=0
l2tpv3_cisco=0
l2tpv3_cisco_vcid=0
l2tpv3_cookie_len=0
l2tpv3_dialondemand=0
lan1_dhcp=0
lan1_domain=
lan1_gateway=192.168.2.1
lan1_hwaddr=
lan1_hwnames=
lan1_ifname=
lan1_ifnames=
lan1_ipaddr=192.168.2.1
lan1_lease=86400
lan1_netmask=255.255.255.0
lan1_proto=dhcp
lan1_route=
lan1_stp=1
lan1_wins=
lan1_wps_oob=enabled
lan1_wps_reg=enabled
lan2_ifname=
lan2_ifnames=
lan3_ifname=
lan3_ifnames=
lan4_ifname=
lan4_ifnames=
lan_dhcp=0
lan_dhcp_1=0
lan_dhcp_dns_1=0.0.0.0 0.0.0.0 0.0.0.0
lan_dhcp_wins_1=0.0.0.0
lan_dns_mode_1=0
lan_domain=
lan_domain_1=
lan_hwaddr=xx:xx:xx:xx:xx:xx
lan_hwnames=
lan_ifname=br0
lan_ifname_1=br0
lan_ifnames=vlan1 eth3
lan_ip_mode=3
lan_ipaddr=192.168.3.1
lan_ipaddr_1=192.168.3.1
lan_ipv6_6to4en=1
lan_ipv6_change=0
lan_ipv6_dhcp=off
lan_ipv6_dhcp_delegate_prefix=
lan_ipv6_dhcp_delegate_prefix_en=0
lan_ipv6_dhcp_delegate_prefixlen=64
lan_ipv6_dhcp_mode=0
lan_ipv6_dhcp_pref=255
lan_ipv6_dhcp_prefer=108000
lan_ipv6_dhcp_rebind=86400
lan_ipv6_dhcp_renew=54000
lan_ipv6_dhcp_valid=216000
lan_ipv6_dns=
lan_ipv6_dns_mode=3
lan_ipv6_dns_primary=
lan_ipv6_dns_secondary=
lan_ipv6_domain=
lan_ipv6_ipaddr=fec0::1
lan_ipv6_prefix=fec0::/64
lan_ipv6_prefixlen=64
lan_ipv6_radvd_advint=30
lan_ipv6_radvd_en=1
lan_ipv6_radvd_hoplimit=64
lan_ipv6_radvd_mflag=off
lan_ipv6_radvd_minadvint=10
lan_ipv6_radvd_mtu=1500
lan_ipv6_radvd_oflag=off
lan_ipv6_radvd_pref=medium
lan_ipv6_radvd_reachabletime=0
lan_ipv6_radvd_retranstimer=0
lan_ipv6_radvd_rtrlifetime=3600
lan_ipv6_radvd_uc=off
lan_lease=86400
lan_lease_1=86400
lan_netmask=255.255.255.0
lan_netmask_1=255.255.255.0
lan_proto=dhcp
lan_proto_1=dhcp
lan_route=
lan_route_1=
lan_stp=0
lan_stp_1=0
lan_wins=
lan_wins_1=
lan_wps_oob=enabled
lan_wps_reg=enabled
lastmem_query_count=2
lastmem_query_interval=1
lltd_enable=1
log_email_auth=3
log_email_auth_pass=7D405303B3E6C5EC2EEF880706CC21F1F71B
log_email_auth_user=serviceit@test.ro
log_email_enable=on
log_email_encrypt=0
log_email_return_addr=serviceit@test.ro
log_email_sendto_addr_0=serviceit@test.ro
log_email_sendto_addr_1=
log_email_sendto_addr_2=
log_email_server_addr=mail.test.ro
log_email_server_port=26
log_email_time=24
log_email_unit=0
log_enable=1
log_ipaddr=0
log_limit_count=1000
log_page_cnt=20
login_time=0
mac_clone_enable=1
machine_name=RV130W
manual_boot_nv=0
model_descr=10/100/1000 4-Port VPN Router
model_name=RV130
mtu_enable=0
multicast_max=25
multicast_pass=1
netbios_enable=0
ntp_enable=1
ntp_mode=auto
ntp_server=
ntp_use_default=1
ntp_use_default_sel=1
old_wan_proto=static
one2one_cnt=0
ping_iface=
ping_ip=5.2.110.125
ping_size=64
ping_times=3
pluto_debug=
pluto_wdebug=
port_detect_enable=1
port_trigger0=
port_trigger10=
port_trigger11=
port_trigger12=
port_trigger13=
port_trigger14=
port_trigger15=
port_trigger16=
port_trigger17=
port_trigger18=
port_trigger19=
port_trigger1=
port_trigger2=
port_trigger3=
port_trigger4=
port_trigger5=
port_trigger6=
port_trigger7=
port_trigger8=
port_trigger9=
ppp_ac=
ppp_auth=0
ppp_demand=0
ppp_get_ac=
ppp_get_srv=
ppp_idletime=5
ppp_mppe=0
ppp_mru=1500
ppp_mtu=1500
ppp_passwd=
ppp_redialperiod=30
ppp_service=
ppp_static=0
ppp_static_ip=
ppp_username=
pppoe_ifname=
pptp_dhcp=0
pptp_get_ip=
pptp_pass=1
pptp_server_ip=
pptpd_account_10=
pptpd_account_1=
pptpd_account_2=
pptpd_account_3=
pptpd_account_4=
pptpd_account_5=
pptpd_account_6=
pptpd_account_7=
pptpd_account_8=
pptpd_account_9=
pptpd_enable=0
pptpd_localip=10.0.0.1
pptpd_remoteip=10.0.0.10-19
pwd_minclass=3
pwd_minlen=8
qkvpn_enable=0
qkvpn_port=443
qos=0
qos_burst_div=10
qos_cburst_div=5
qos_cos_data=11333444
qos_dscp_data=1111111111111111333333333333333333333333444444443333333333333333
qos_lan_ctl=1
qos_lan_manual_rate=40960
qos_lan_speed=71680
qos_perport_prio=1,0,3;2,0,3;3,0,3;4,0,3
qos_rate_mode=0
qos_smt_cnt=0
qos_wan_ctl=1
qos_wan_manual_rate=10240
qos_wan_speed=71680
query_interval=125
query_response_interval=10
remote_ip=0.0.0.0 0
remote_ip_any=1
remote_management=1
remote_mgt_https=1
remote_upgrade=1
ripng_enable=0
robustness=2
rogue_ap_enable=0
router_disable=0
rstp_fdelay=15
rstp_fversion=0
rstp_hellotime=2
rstp_maxage=20
rstp_port10_edge=0
rstp_port10_enable=0
rstp_port10_pathcost=0
rstp_port11_edge=0
rstp_port11_enable=0
rstp_port11_pathcost=0
rstp_port12_edge=0
rstp_port12_enable=0
rstp_port12_pathcost=0
rstp_port13_edge=0
rstp_port13_enable=0
rstp_port13_pathcost=0
rstp_port14_edge=0
rstp_port14_enable=0
rstp_port14_pathcost=0
rstp_port1_edge=0
rstp_port1_enable=0
rstp_port1_pathcost=0
rstp_port2_edge=0
rstp_port2_enable=0
rstp_port2_pathcost=0
rstp_port3_edge=0
rstp_port3_enable=0
rstp_port3_pathcost=0
rstp_port4_edge=0
rstp_port4_enable=0
rstp_port4_pathcost=0
rstp_port5_edge=0
rstp_port5_enable=0
rstp_port5_pathcost=0
rstp_port6_edge=0
rstp_port6_enable=0
rstp_port6_pathcost=0
rstp_port7_edge=0
rstp_port7_enable=0
rstp_port7_pathcost=0
rstp_port8_edge=0
rstp_port8_enable=0
rstp_port8_pathcost=0
rstp_port9_edge=0
rstp_port9_enable=0
rstp_port9_pathcost=0
rstp_priority=32768
send_email=0
sip_alg_enable=0
sip_alg_manual=0
smtb_01=5,1,65535,All Traffic
smtb_02=1,53,53,DNS
smtb_03=0,21,21,FTP
smtb_04=0,80,80,HTTP
smtb_05=0,8080,8080,HTTP Secondary
smtb_06=0,443,443,HTTPS
smtb_07=0,8443,8443,HTTPS Secondary
smtb_08=1,69,69,TFTP
smtb_09=0,143,143,IMAP
smtb_10=0,119,119,NNTP
smtb_11=0,110,110,POP3
smtb_12=1,161,161,SNMP
smtb_13=0,25,25,SMTP
smtb_14=0,23,23,TELNET
smtb_15=0,8023,8023,TELNET Secondary
smtb_16=0,992,992,TELNET SSL
smtb_17=2,5060,5061,Voice(SIP)
smtb_cnt=17
snmp_0_enable=0
snmp_contact=
snmp_enable=0
snmp_getcom=public
snmp_location=
snmp_mode=1
snmp_setcom=private
snmp_trap_log_level=4
snmp_vpn_access=0
snmpv3_0_auth=MD5
snmpv3_0_authpwd=
snmpv3_0_priv=DES
snmpv3_0_privpwd=
snmpv3_0_seclevel=0
snmpv3_0_user=admin
snmpv3_1_auth=MD5
snmpv3_1_authpwd=
snmpv3_1_priv=DES
snmpv3_1_privpwd=
snmpv3_1_seclevel=0
snmpv3_1_user=guest
snmpv3_engineid=80000009033CCE738E759B
snoop_except_port=1900,5353
sock_rmem_max=66560
ssid=ciscosb4
startup_query_count=2
startup_query_interval=31
static_route=192.168.0.0:255.255.255.0:5.2.110.125:0:eth1
static_route_name=$NAME:vpn1$$
stats_server=
submit_button=firewall
success_flg=1
switch_tag_map=0
syslog-ng_init=1
syslog-ng_service=All,Kernel,System,Wireless
syslog_full_flg=0
syslog_group0=0,"",31,1,1,1
syslog_ram_group0=0,"",31,1,1,1
test_channel=0
test_email_addr_0=serviceit@test.ro
tftpd_enable=0
throughput_test=0
time_zone=+02 2 2
timer_interval=1800
traceroute_iface=
traceroute_ip=192.168.0.18
trap_0_com=
trap_0_ip=
trap_0_port=
trap_0_ver=v1
trap_1_com=
trap_1_ip=
trap_1_port=
trap_1_ver=v1
tz_backup=0
upnp_config=0
upnp_enable=1
upnp_event=1
upnp_forward_max=0
upnp_internet_dis=0
upnp_max_age=180
upnp_signal=1
upnp_ssdp_interval=60
upnp_wan_proto=
ure_disable=1
vlan_group=1
vlan_name_1=Default
vlan_ports_1=0 1 2 3 5*
vlan_selidx=0
vpn_1_dpd_delay=
vpn_1_dpd_enable=0
vpn_1_dpd_retry=
vpn_1_exchange_mode=main
vpn_1_ike_authentication_method=
vpn_1_ike_dh_group=modp1024
vpn_1_ike_esp=3des
vpn_1_ike_hash_algorithm=sha1
vpn_1_ike_idx=1
vpn_1_ike_name=VPN1
vpn_1_ike_pskpwd=cisco12345
vpn_1_ike_sa_ltime=28800
vpn_1_ipsec_auto_ah=sha1
vpn_1_ipsec_auto_esp=3des
vpn_1_ipsec_idx=1
vpn_1_ipsec_key_type=0
vpn_1_ipsec_name=VPN1
vpn_1_ipsec_pfs_enable=1
vpn_1_ipsec_pfs_group=modp1024
vpn_1_ispi=
vpn_1_lgroup_ip=192.168.3.0
vpn_1_lgroup_mask=255.255.255.0
vpn_1_lgroup_type=1
vpn_1_local_id=
vpn_1_local_id_type=0
vpn_1_mah_in_content=
vpn_1_mah_key=
vpn_1_mah_out_content=
vpn_1_mesp_in_content=
vpn_1_mesp_key=
vpn_1_mesp_out_content=
vpn_1_natt_enable=0
vpn_1_netbios_enable=0
vpn_1_ospi=
vpn_1_policy_enable=1
vpn_1_policy_using_ike_idx=1
vpn_1_pskid=
vpn_1_remote_end_fqdn=
vpn_1_remote_end_ip=5.2.110.125
vpn_1_remote_end_type=0
vpn_1_remote_id=
vpn_1_remote_id_type=0
vpn_1_rgroup_ip=192.168.0.0
vpn_1_rgroup_mask=255.255.255.0
vpn_1_rgroup_type=1
vpn_1_sa_ltime=3600
vpn_1_xauth_client_enable=
vpn_1_xauth_client_id=
vpn_1_xauth_client_pw=
vpn_account_1=
vpn_account_2=
vpn_account_3=
vpn_account_4=
vpn_account_5=
vpn_client_stat_1=0 __ __ __ __
vpn_client_stat_2=0 __ __ __ __
vpn_client_stat_3=0 __ __ __ __
vpn_client_stat_4=0 __ __ __ __
vpn_client_stat_5=0 __ __ __ __
vpn_show_unit=1
wan_active_connection=1
wan_dns=213.154.124.1 193.231.252.1
wan_dns_mode=0
wan_domain=
wan_gateway=5.2.110.97
wan_gateway_buf=0.0.0.0
wan_get_dns=
wan_get_domain=
wan_hostname=router8E759B
wan_hwaddr=xx:xx:xx:xx:xx:xx
wan_hwname=
wan_ifname=eth1
wan_ifnames=eth1
wan_ip_mode=3
wan_ipaddr=5.2.110.117
wan_ipaddr_buf=0.0.0.0
wan_ipaddr_used=0
wan_ipv6_dns=
wan_ipv6_domain=
wan_ipv6_gateway=
wan_ipv6_ipaddr=
wan_ipv6_lease=0
wan_ipv6_life=0
wan_ipv6_prefix=
wan_ipv6_proto=dhcp
wan_ipv6_rebind=0
wan_ipv6_renew=0
wan_ipv6_sntp=
wan_lease=0
wan_mtu=1500
wan_netmask=255.255.255.224
wan_pptp_dhcp_dns=
wan_pptp_dns0=
wan_pptp_dns1=
wan_pptp_dns2=
wan_primary=1
wan_proto=static
wan_proto_last=static
wan_real_gateway=5.2.110.97
wan_real_ifname6=eth1
wan_real_ifname=eth1
wan_real_ipaddr=5.2.110.117
wan_real_netmask=255.255.255.224
wan_run_mtu=1500
wan_speed=4
wan_static_dns_mode=2
wan_unit=0
wan_wins=
web_wl_filter=1
wk_mode=gateway
wl0.1_akm=
wl0.1_ap_isolate=0
wl0.1_ap_vlan_id=1
wl0.1_auth_mode=none
wl0.1_auth_type=0
wl0.1_bss_enabled=0
wl0.1_bss_maxassoc=16
wl0.1_closed=1
wl0.1_crypto=tkip
wl0.1_key1=
wl0.1_key2=
wl0.1_key3=
wl0.1_key4=
wl0.1_key=1
wl0.1_macfilter_allow=1
wl0.1_macfilter_enable=0
wl0.1_maclist=
wl0.1_passphrase=
wl0.1_radio=1
wl0.1_radius_ipaddr=
wl0.1_radius_key=
wl0.1_radius_port=1812
wl0.1_security_mode=disabled
wl0.1_ssid=ciscosb2
wl0.1_tda_enable=0
wl0.1_tda_start=00:00
wl0.1_tda_stop=00:00
wl0.1_vlan_id=1
wl0.1_wep=disabled
wl0.1_wme=on
wl0.1_wme_bss_disable=0
wl0.1_wpa_gtk_rekey=3600
wl0.1_wpa_psk=
wl0.1_wps_config_state=0
wl0.1_wps_mode=disabled
wl0.2_akm=
wl0.2_ap_isolate=0
wl0.2_ap_vlan_id=1
wl0.2_auth_mode=none
wl0.2_auth_type=0
wl0.2_bss_enabled=0
wl0.2_bss_maxassoc=16
wl0.2_closed=1
wl0.2_crypto=tkip
wl0.2_key1=
wl0.2_key2=
wl0.2_key3=
wl0.2_key4=
wl0.2_key=1
wl0.2_macfilter_allow=1
wl0.2_macfilter_enable=0
wl0.2_maclist=
wl0.2_passphrase=
wl0.2_radio=1
wl0.2_radius_ipaddr=
wl0.2_radius_key=
wl0.2_radius_port=1812
wl0.2_security_mode=disabled
wl0.2_ssid=ciscosb3
wl0.2_tda_enable=0
wl0.2_tda_start=00:00
wl0.2_tda_stop=00:00
wl0.2_vlan_id=1
wl0.2_wep=disabled
wl0.2_wme=on
wl0.2_wme_bss_disable=0
wl0.2_wpa_gtk_rekey=3600
wl0.2_wpa_psk=
wl0.2_wps_config_state=0
wl0.2_wps_mode=disabled
wl0.3_akm=
wl0.3_ap_isolate=0
wl0.3_ap_vlan_id=1
wl0.3_auth_mode=none
wl0.3_auth_type=0
wl0.3_bss_enabled=0
wl0.3_bss_maxassoc=16
wl0.3_closed=1
wl0.3_crypto=tkip
wl0.3_key1=
wl0.3_key2=
wl0.3_key3=
wl0.3_key4=
wl0.3_key=1
wl0.3_macfilter_allow=1
wl0.3_macfilter_enable=0
wl0.3_maclist=
wl0.3_passphrase=
wl0.3_radio=1
wl0.3_radius_ipaddr=
wl0.3_radius_key=
wl0.3_radius_port=1812
wl0.3_security_mode=disabled
wl0.3_ssid=ciscosb4
wl0.3_tda_enable=0
wl0.3_tda_start=00:00
wl0.3_tda_stop=00:00
wl0.3_vlan_id=1
wl0.3_wep=disabled
wl0.3_wme=on
wl0.3_wme_bss_disable=0
wl0.3_wpa_gtk_rekey=3600
wl0.3_wpa_psk=
wl0.3_wps_config_state=0
wl0.3_wps_mode=disabled
wl0_akm=psk2
wl0_ap_isolate=0
wl0_ap_mgmt_vlan_id=1
wl0_ap_vlan_id=1
wl0_auth=0
wl0_auth_mode=none
wl0_auth_type=0
wl0_bcn=100
wl0_bss_enabled=1
wl0_bss_maxassoc=16
wl0_bss_radio_on=1
wl0_channel=0
wl0_closed=0
wl0_country_rev=0
wl0_crypto=aes
wl0_dtim=1
wl0_frag=2346
wl0_frameburst=on
wl0_gmode=1
wl0_gmode_protection=auto
wl0_key1=
wl0_key2=
wl0_key3=
wl0_key4=
wl0_key=1
wl0_macfilter_allow=1
wl0_macfilter_enable=0
wl0_maclist=
wl0_mrate=0
wl0_nbw=20
wl0_nbw_cap=0
wl0_net_mode=mixed
wl0_nmcsidx=-2
wl0_nmode=-1
wl0_nmode_protection=auto
wl0_osifs=eth3 wl0.1 wl0.2 wl0.3
wl0_passphrase=
wl0_radio=1
wl0_radius_ipaddr=
wl0_radius_key=
wl0_radius_port=1812
wl0_rate=0
wl0_rateset=default
wl0_rts=2347
wl0_security_mode=wpa2_personal
wl0_ssid=ciscosb1
wl0_tda_enable=0
wl0_tda_start=00:00
wl0_tda_stop=00:00
wl0_vlan_id=1
wl0_wds_bridge_maclist=
wl0_wds_enable=0
wl0_wds_mode=repeater
wl0_wds_repeater_mode=signal_repeated_by_other
wl0_wds_repeater_other_maclist=
wl0_wds_repeater_self_maclist=
wl0_wep=disabled
wl0_wep_bit=64
wl0_wme=on
wl0_wme_bss_disable=0
wl0_wme_no_ack=off
wl0_wmf_bss_enable=0
wl0_wpa_gtk_rekey=3600
wl0_wpa_psk=DFCF1CBB5500DA8629688E1021132B1F65E7DE22FD614EC90A9339609C9276B21D51
wl0_wps_btn_index=0
wl0_wps_config_state=0
wl0_wps_mode=enabled
wl_akm=psk2
wl_ap_isolate=0
wl_ap_mgmt_vlan_id=1
wl_auth=0
wl_auth_mode=none
wl_auth_type=0
wl_bcn=100
wl_bss_enabled=1
wl_bss_maxassoc=64
wl_channel=0
wl_closed=0
wl_country_rev=0
wl_crypto=aes
wl_dispatch_mode=1
wl_dtim=1
wl_frag=2346
wl_frameburst=on
wl_gmode=1
wl_gmode_protection=auto
wl_key1=
wl_key2=
wl_key3=
wl_key4=
wl_key=1
wl_maclist=
wl_mrate=0
wl_nbw=20
wl_nbw_cap=0
wl_net_mode=mixed
wl_nmcsidx=-2
wl_nmode=-1
wl_nmode_protection=auto
wl_osifs=eth3 wl0.1 wl0.2 wl0.3
wl_passphrase=
wl_radio=1
wl_radius_ipaddr=
wl_radius_key=
wl_radius_port=1812
wl_rate=0
wl_rateset=default
wl_rts=2347
wl_security_mode=wpa2_personal
wl_ssid=cisco_sb
wl_tda_enable=0
wl_tda_start=00:00
wl_tda_stop=00:00
wl_wds_bridge_maclist=
wl_wds_enable=0
wl_wds_mode=repeater
wl_wds_repeater_mode=signal_repeated_by_other
wl_wds_repeater_other_maclist=
wl_wds_repeater_self_maclist=
wl_wep=disabled
wl_wep_bit=64
wl_wme=on
wl_wme_bss_disable=0
wl_wme_no_ack=off
wl_wmf_bss_enable=0
wl_wpa_gtk_rekey=
wl_wpa_psk=
wl_wps_btn_index=0
wl_wps_config_state=0
wl_wps_mode=enabled
wpspin_lifetime=20
wwan_apnname=
wwan_auth=auto
wwan_back_gw=5.2.110.97
wwan_back_ifname=eth1
wwan_back_ip=5.2.110.117
wwan_back_mask=255.255.255.224
wwan_cap_day=1
wwan_cap_enabled=0
wwan_cap_flash_rx=
wwan_cap_flash_tx=
wwan_cap_percentage=0
wwan_cf_sel_time=1
wwan_cf_sel_time_end=13,00
wwan_cf_sel_time_start=12,00
wwan_cf_timeout=10
wwan_cf_validgw=1
wwan_cf_validsite6=0000:0000:0000:0000:0000:0000:0000:0000
wwan_cf_validsite=0.0.0.0
wwan_config_mode=1
wwan_connect_failover=1
wwan_connect_mode=0
wwan_connect_recovery=1
wwan_cr_timeout=60
wwan_demand=0
wwan_dialnum=
wwan_idletime=5
wwan_lte_type=auto
wwan_mail_cf=0
wwan_mail_cf_tmp=recovery
wwan_mail_failover_sent=0
wwan_mail_interval=30
wwan_mail_percentage=0
wwan_mail_period=0
wwan_mail_recovery_sent=1
wwan_passwd=
wwan_pincode=
wwan_priority=eth
wwan_server_name=
wwan_service=umtspre
wwan_simcheck=1
wwan_status=
wwan_test=1
wwan_username=
Can just make out the vpn settings from the output, I think were OK. On the SSG please show the output of "get sa" to be sure, i must mention that if it is route based VPN or policy based, on the SSG make policy permit rules are in place to permit traffic from the tunnel interface zone you bind vpn to. Also please insure that the routes on the SSG and the cisco are ok.
If possible, output the configuration of the SSG so I can have a look. Thank you
Bilal
