08-27-2020 07:10 PM
Hi, all.
i am new learner for Cisco AP1850i. For network site (without DHCP) , Cisco AP 1850i can connect to Cisco MX64W without DHCP setting?
08-28-2020 12:00 AM
it depends how both the Meraki and the AP are set up. Can you post the configs of both devices ? Check if they have static IP addresses...
08-28-2020 01:38 AM
08-28-2020 12:23 AM
Hello
Have you set the ap up correctly in the dashboard- is it registered.
you can only really assign static/dynamic addressing if you desire from there as meraki is cloud based service
lastly regards dhcp have you created the l3 interface in the MX for the ap and assigned the AP to the vlan
08-28-2020 02:32 AM
