Cisco switch command to show the ip address range assigned to each vlan on the network
Please help.....What is the Cisco switch command to show the ip address range assigned to each vlan on the network
you need a layer 3 switch with the SVIs (Vlan interfaces) do see that. On that layer 3 switch, issue the command:
Switch#sh run | include interface Vlan|ip address
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan30
ip address 192.168.30.1 255.255.255.0
balaji.bandi
show ip interface brief  - will give you information what IP and mask configured to the interface - is that make sense ? or work for you ?
BB
interface Vlan10
interface Vlan20
interface Vlan30
Georg Pauwen,
Thanks so much. I will like to know if there is a command I can run on Nexus switch to show the ip address range assigned to each vlan on the network? For example Staff_vlan 100 what are the valid ip address for this vlan? I would like a list of vlans and their address ranges.
Please help out
