11-23-2016 07:58 AM - edited 03-05-2019 07:32 AM
Hi!
If anyone can guide me!!
I have the following scenario:
IP: A.A.A.A |SERVER|------------|ASA 5506X|<------IPSEC------->|ASAXXXX|-------------|SERVER| IP: B.B.B.B
The vpn ipsec specifications :
Left peer (asa5506x) ip: X.X.X.X
domain encryption : 10.5.41.0/24
Right peer (ASAXXX) ip:XX.XX.XX.XX
domain encryption : 10.5.43.0/24
I do not know how to mask the ip address A.A.A.A(ORIGINAL) whit 10.5.41.xx to generate traffic to the other side.
With iptables(openswan) can do it :
iptables -t nat -I POSTROUTING -s A.A.A.A -d 10.5.43.5/32 -j snat --to 172.16.41.100
Whit cisco asa , i don know...
Someone help me?
PD: i have access to ASA5506X.
Solved! Go to Solution.
11-23-2016 11:11 AM
I do not understand what you are telling me. It sounds like perhaps you are saying that you need to NAT the traffic. Is that the case?
Rick
11-23-2016 08:07 AM
This link has a good discussion and examples which I hope will be helpful to you for configuring site to site VPN on ASA
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/119141-configure-asa-00.html
Rick
11-23-2016 08:26 AM
Thanks! Richard! very fast Answer!
The link, is helpful , but in the example the domain encryption in both sides are "real". In my case, the domain encryption on both sides are "ficticius" , the "real" ips must be masquerade.
The tunnel is up but I can not generate traffic, since the source ip are not interesting traffic. I need to mask those ip's to format 10.5.41.0/24.
11-23-2016 11:11 AM
Rick
11-24-2016 08:41 AM
Sorry !
I need all the traffic that originates in my encrypted domain , example 172.16.1.254, be masked with ip 10.5.41.254 , In this way the traffic is directed by the vpn.
And all the traffic that comes from 10.5.43.100 (example) ,Head towards 172.16.1.254.
I explain ?
