Cisco ASA command line output taking 20-25 seconds to display output
ujwal-koteesh
Cisco ASA command line output taking 20-25 seconds to display command output and this is causing serious delays in processing the output by other servers from this device.
If I enter # show interface or
#show run
These commands are taking more than 25 seconds before the prompt(#) is returned.
Here is the output of "show run aaa" command:
ASA-5508-77251(config)# show run aaa
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authentication serial console LOCAL
aaa authentication telnet console LOCAL
aaa authorization command LOCAL
aaa accounting serial console ISE
aaa accounting telnet console ISE
aaa accounting ssh console ISE
aaa accounting command ISE
aaa accounting enable console ISE
aaa authorization exec authentication-server auto-enable
aaa authentication login-history
Mark Elsen
  - Check the software version being used on the ASA and or upgrade to the latest advisory version for the particular ASA-model that you have => Check if that can help ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
aaa authorization command LOCAL <<- this command I think the issue' try remove it and check the time taken for command
MHM
