Cisco ASA icmp traffic flow issue for specific sub-interface
netdiver81
Trying to troubleshoot an issue in which icmp traffic when originating behind one of the ASA subinterfaces does not go through (or better return) correctly when destination is behind this problematic interface.
I originally identified the issue as I was trying to ping from clients behind another sub-interface to this sub-interface clients and I did not get echo replies back even though I added/allowed echo replies back (I see the echo replies counter increase). Other traffic UDP works but this does not require a rule in the opposite direction.
What's strange is that when I do a policy trace from behind the problematic interface the destination interface is always identified as the outside interface even though destination address is behind other sub-interfaces on same firewall. It is as if any traffic from behind this problematic interface is forced to the outside interface. (and thus dropped)
Any idea why this would happen, all other interfaces seem to be working fine and identifying the destination interface correctly.
Richard Burts
We do not have much detail to work with and that makes it difficult to give good advice. As a start can you tell us if ping from a device on the inside interface to some destination on the outside interface works?
As a next step can you tell us about the inside, outside, and problematic interfaces? What are their security levels? Are there security policies configured for these interfaces and the subnets reached through them?
Rick
Hi Rick,
It was a missing route-lookup within a NAT that caused this hence why all traffic was going to outside.
Thanks for the update. And for the explanation of the problem. I am always glad when someone posts a problem and then finds the solution to their own problem and shares it with the community. A well deserved +5 for you.
Rick
