Cisco ASR1002-F Problem boot iOS through usb
miljanmarjanac
Hi all,
I have a problem with the cisco ASR1002-f, I can't boot iOS throught usb flash and flash memory.
ASR1002-F logs:
rommon 7 > boot usb0:asr1000rp1-adventerprisek9.03.16.05.S.155-3.S5-ext.bin
Located asr1000rp1-adventerprisek9.03.16.05.S.155-3.S5-ext.bin, start cluster is 6
File is comprised of 1 fragments (0%)
Image loaded
Booting image with bootparam="root=/dev/ram rw console=ttyS2,9600 max_loop=64 SR_BOOT=usb0:asr1000rp1-adventerprisek9.03.16.05.S.155-3.S5-ext.bin"
Boot image size = 393001596 (0x176cba7c) bytes
Read midplane macaddr base: d0:d0:fd:2e:78:00
Mac blocksize = 256
Returning macaddr: d0:d0:fd:2e:78:ff
Using midplane macaddr
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated d6d8789d:df2e0f1e:ba9c4d4e:a5e6e03c:fe319eb8
expected d6d8789d:df2e0f1e:ba9c4d4e:a5e6e03c:fe319eb8
Package type:30000, flags:0x0
Parsing package TLV info:
000: 00000009:0000001d:4b45595f:544c565f - KEY_TLV_
010: 5041434b:4147455f:434f4d50:41544942 - PACKAGE_COMPATIB
020: 494c4954:59000000:00000009:0000000b - ILITY
030: 4652555f:52505f54:59504500:00000009 - FRU_RP_TYPE
040: 00000018:4b45595f:544c565f:5041434b - KEY_TLV_PACK
050: 4147455f:424f4f54:41524348:00000009 - AGE_BOOTARCH
060: 0000000d:41524348:5f707063:5f545950 - ARCH_ppc_TYP
070: 45000000:00000009:00000014:4b45595f - E KEY_
080: 544c565f:424f4152:445f434f:4d504154 - TLV_BOARD_COMPAT
090: 00000009:0000000e:424f4152:445f7270 - BOARD_rp
0a0: 315f5459:50450000:00000009:00000018 - 1_TYPE
0b0: 4b45595f:544c565f:43525950:544f5f4b - KEY_TLV_CRYPTO_K
0c0: 45595354:52494e47:00000009:0000000a - EYSTRING
TLV(0): T=9, L=29, V=KEY_TLV_PACKAGE_COMPATIBILITY
Key detected
TLV(1): T=9, L=11, V=FRU_RP_TYPE
found package fru type FRU_RP_TYPE
Realigning image in memory prior to launch...
Image validated
%IOSXEBOOT-4-DEVICE_MISSING: (rp/0): Integrity check for missing device /dev/bootflash not performed.
%IOSXEBOOT-1-BOOTFLASH_FAILED_MISSING: (rp/0): Required Bootflash disk failed or missing, reloading system
Kernel core dump: missing device /dev/bootflash1
System Bootstrap, Version 12.2(33r)XND1, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
SPD PROM contents for slot 0
8008080E 0A614800 05304502 82080800 0C083801 1004033D 5050603C 1E3C2D01
20271017 3C1E1E00 063C7F80 18220F00 00000000 00000000 00000000 00001246
calculated chksum = 00000046; stored chksum = 00000046
SPD PROM contents for slot 1
Clearing bss... done
CPU Version: 2.1.x
CPU Clock freqs: sys:100000000 CCB:400000000 Core:1400000000
local:50000000 i2c:97656 MII:1785714
CPLD Version: 23 (MM/DD/YY): 01/10/08 ASR1002-RP1 Slot:0
Current image running: Boot ROM1
Last reset cause: Watchdog
Last reset at: Tue Mar 17 09:42:47 UTC 2020
Reading confreg 0x8141
Reading monitor variables from NVRAM
Enabling interrupts Initializing USB host controller...done
ASR1002-RP1 platform with 4194303 Kbytes of main memory
autoboot entry: NVRAM VALUES: bootconf: 0x1, autobootstate: 0
autobootcount: 0, autobootsptr: 0x0
no valid BOOT image found
Final autoboot attempt from default boot device...
media drive bootflash: not present
boot: cannot determine first file name on device "bootflash:"
autoboot: boot failed, restarting...
Mark Elsen
 - Not exactly the same but you may need to upgrade the ROMMON :
              https://bst.cloudapps.cisco.com/bugsearch/bug/CSCso83288/?rfs=iqvred
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
