CISCO ASR9010
rizwanhaider
Dear All,
I have some queries regadign ASR 9010.
Q.1    What is the packet forwarding capacity in Mpps of ASR9010 and either it is in Unidirectional or Bidirectional ?
Q.2    When two RSPs are used in Active/Active configuration then i case of one RSP failure users will face how much interuption in service
Q.3    What is the exact per slot throughput of ASR9010 ?
Urgent response will be highly appreciated
Muhammad Saleem
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Q1.
Usually forwarding is total capacity is used for any forwarding whether unidirectional or bidirectional.
Mpps would depend what's installed in the chassis as the ASR 9000 also supports distributed forwarding.
Q2.
http://www.cisco.com/en/US/docs/routers/asr9000/hardware/overview/guide/asr9kOVRGHAredundancy.html#wp710094
Q3.
http://www.cisco.com/en/US/docs/routers/asr9000/hardware/overview/guide/asr9kOVRGfuncdescription.html#wp706946
