Cisco Cat9K Route leaking between VRF and GRT
GoncaloContente
Hi, i am trying to configure route leaking between  VRF and GRT in Cat 9k. On my Cat 9k i have the following configuration:
VRF Conf:
Switch_LAB#sh vrf
  Name                             Default RD            Protocols   Interfaces
  LAB                              <not set>             ipv4        Vl120
Switch_LAB#sh run int vlan 120
Building configuration...
Current configuration : 91 bytes
interface Vlan120
 vrf forwarding LAB
 ip address 10.120.0.254 255.255.255.0
end
My routes are configured as follows:
Switch_LAB_#sh run | i route
ip route 0.0.0.0 0.0.0.0 10.1.0.1
ip route 10.120.0.0 255.255.255.0 Vlan120 10.120.0.254 name LAB
ip route vrf LAB 0.0.0.0 0.0.0.0 Vlan1 10.1.0.1 global
According to the documentation i have been reading, route leak should be possible with static routes but for some reason i am unable to ping Int Vlan 1 which is on the GRT from the VRF LAB. Any ideas why is not working???
thanks for that , i see this doc too i think the explanations are a bit clearer , i think you should try use a physical interface here rather than a logical one
maybe try option 2 the way its setup in this doc and see if it allows it then
https://ipwithease.com/route-leaking-between-vrf-and-global-routing-table/
12 Replies 12
omz
i am sure you are using "vrf" in ping .. sometime people forget :)
my bad .. you are unable to ping vlan1 from vrf .. right?
Hi omc79,
Thanks for replying. Im unable to ping from vlan1 and from the VRF.
BTW i am using the "vrf" in the ping.
Cheers
could you post the doc you are reading from i was trying to find it to check this please
Hi Mark
doc: Configure Route Leaking Between Global and VRF Routing Table without Next-Hop
This doc is a quick guide on how to configure route leaking without Next-Hop, however in the Doc introduction it state that route leaking can be achieved by configuring static routes and of course by providing a next-hop for those routes.
Using your config .. I can ping from vrf to local vlan 1 in global table.
IOU4(config)#do ping  10.1.0.2  so vl 120
Sending 5, 100-byte ICMP Echos to 10.1.0.2, timeout is 2 seconds:
Packet sent with a source address of 10.120.0.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/7/8 ms
IOU4(config)#do sh run int vlan 1
Current configuration : 58 bytes
interface Vlan1
 ip address 10.1.0.2 255.255.255.0
end
But I cannot ping the next hop - 10.1.0.1
IOU4(config)#do ping  10.1.0.1  so vl 120
Sending 5, 100-byte ICMP Echos to 10.1.0.1, timeout is 2 seconds:
*Jun  5 06:48:59.465: %ADJ-3-RESOLVE_REQ: Adj resolve request: Failed to resolve 10.120.0.254 Vlan120...
*Jun  5 06:49:05.480: %ADJ-3-RESOLVE_REQ: Adj resolve request: Failed to resolve 10.120.0.254 Vlan120..
Success rate is 0 percent (0/5)
Can ping from global table to vrf - without using the vrf keyword.
IOU4(config)#do ping 10.120.0.254
Sending 5, 100-byte ICMP Echos to 10.120.0.254, timeout is 2 seconds:
IOU4(config)#do sh ip route | b Ga
Gateway of last resort is 10.1.0.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.1.0.1
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.1.0.0/24 is directly connected, Vlan1
L        10.1.0.2/32 is directly connected, Vlan1
S        10.120.0.0/24 [1/0] via 10.120.0.254, Vlan120
IOU4(config)#
omz
I tired with physical interface .. didnt get the below message .. but still cannot ping next hop with vrf source. Local ping works fine.
IOU4(config)#do sh run int e0/1
Current configuration : 106 bytes
interface Ethernet0/1
 no switchport
 ip vrf forwarding LAB
end
IOU4(config)#do ping 10.1.0.2 so e0/1
IOU4(config)#do ping 10.1.0.1 so e0/1
Hi omc79
Can you post the route table?
Hi omc79
Are you using a L3 or a L2 image?
in my demo i need to do route leak using logical interfaces
Cheers
Hello Goncalo,
I think you should try to use option 3 of the document provided by Mark.
In this option 3 you will use two GRE tunnels to create a "virtual cable" to connect the VRF and the GRT.
One GRE Tunnel is in GRT and the other GRE Tunnel is associated in the VRF. GRE tunnels use loopback addresses in GRT as source and destination addresses.
The two tunnels provide a shared subnet to perform routing and forwarding between GRT and the VRF.
Hope to help
Giuseppe
Hi Guiseppe,
The 3 option looks rather interesting. i will give it a try.
Hi omc79
I dont know how IOU images process traffic, but in real gear you have to use the "vrf" when ping from a VRF.
Switch_LAB#ping 10.1.0.2 sour vlan 120
% Invalid source interface - Interface vrf does not match the vrf used for ping
Cheers
