Cisco commands
kumarpmt83
what is the meaning for the below commands
no ip redirects
no ip unreachables
ip virtual-reassembly
no ip route-cache
ip tcp adjust-mss 1420
no cdp enable
no keepalive
no ip route-cache flow
no ip directed broadcast
nkarpysh
You can use lookup tool to locate the commands you need:
http://tools.cisco.com/Support/CLILookup/cltSearchAction.do
Just search for a command without a NO in the beginning and then you can see from it what NO option is doing for it.
Hope this helps,
Nik
HTH,
Niko
johnlloyd_13
Level 9
Level 9
hi,
a google search can also be your bestfriend!
