Cisco Interface Shaping
Simon Young
I am setting up a shaper for my ISP facing interface.
I went to apply
max-reserved-bandwidth 100 under my interface
My question is, how do I apply the same command or something that does the same thing?
policy-map Shaper
class class-default
shape average 36800000
bandwidth 100
I was reading the article below and noticed that max reserved is a depeciated command, does the above bandwidth statement do the same thing?
http://www.cisco.com/c/en/us/td/docs/ios/ios_xe/qos/configuration/guide/convert/qos_mqc_xe/legacy_qos_cli_deprecation_xe.html
JohnTylerPearce
Level 7
Level 7
Simon,
I believe with older IOS images, the default was tosave 25% for control plane traffic, because Cisco didn't trust us engineers I guess. Now, they completely trust us, and it's up to us to not be stupid.
I would do the following.
Let's say you have 100Mbps Internet link going to your ISP on Router
policy-map 100M_SHAPE
class class-default
shape average 100000000
int x/x     <-- Interface going to your ISP from your Router
service-policy out 100M_SHAPE
***** Edit *****
If you have control plane traffic, or any other traffic, you want to have some priority too, you can always include
a child policy-map to the parent 100M_SHAPE
Thanks for the prompt response
My bad - the connection is dot1q to the provider, hence the need for the shaping due to the ethernet overhead
So I have 40 Mb connection and it works out at a shape average 36800000
I think you have answered my question though, reading into it, I don't need that line of config
