Cisco IOS 17.9.04a multi IP WAN configuration
Slavec
Hi there, I have a cisco 1111X-8P running IOS 17.9.04a. My ISP upgraded me to a PRO fiber connection, basically no more DHCP on WAN interface with one IP, I got a /29 block, so now I'm PRO.
What I want to do;
Say, my IP's are:
.1 network
.2 first hop
.3 cisco 1111x WAN IP
.4 LAN traffic
.5 XBOX
.8 broadcast network
Now, with my regular NAT setup (below), every client has .3 [cisco] as a wan IP. How can I make my LAN use .4 as their WAN IP and specifically the XBOX, also in LAN use .5 ??
current NAT setup:
ip nat inside source route-map KETENBAAN interface GigabitEthernet0/0/1.1 overload
route-map KETENBAAN permit 1
match ip address 161
ip access-list extended 161
10 remark alle lans mogen naar buiten
10 remark ------------------------------------------------
10 permit ip 10.0.0.0 0.255.255.255 any
20 remark ------------------------------------------------
20 deny ip 192.168.178.0 0.0.0.255 10.15.161.0 0.0.0.255
30 permit ip 192.0.0.0 0.255.255.255 any
The 192.168 network is a guest network.
Much obliged for any input,
SvdM
Hello @Slavec ,
one way of doing what you described is as follows:
1. erase the old NAT configuration - disconnect the WAN interface before starting in order to clear NAT translations already on the router
ANconf t
no ip nat inside source route-map KETENBAAN interface GigabitEthernet0/0/1.1 overload
no route-map KETENBA
2. define 2 address pools for the 2 NAT translations
conf t
ip nat pool LAN-pool x.x.x.4 prefix-length 24
ip nat pool XBOX-pool x.x.x.5 prefix-length 24
3. reconfigure access-list for LAN NAT - we are going to deny the IP address of the XBOX in order to not having it NATed with the whole LAN
conf t
5 remark deny IP address of XBOX
5 deny ip host <XBOX IP address> any
4. Configure IP access-list only for XBOX
conf t
ip access-list extended 162
permit ip host <XBOX IP address> any
5. Configure new NAT statements:
ip nat inside source list 161 pool LAN-pool overload
ip nat inside source list 162 pool XBOX-pool overload
If disconnecting the WAN interface is not possible, you can remove the command
ip nat inside
from the LAN interface - this will erase all NAT translations that are in effect on the router giving you the possibility to erase the old NAT commands.
After finishing the reconfiguration, do not forget to put the command
ip nat inside
on the LAN interface.
Regards, LG
*** Please Rate All Helpful Responses ***
6 Replies 6
Hello @Slavec ,
ANconf t
conf t
conf t
conf t
ip nat inside
ip nat inside
Regards, LG
conf t
So, my WAN int gi 0/0/1.1
ip address 31.161.18.114 255.255.255.248
ip address 31.161.18.115 255.255.255.255 secondary
ip address 31.161.18.117 255.255.255.255 secondary
(/29 block)
so..
ip nat pool LAN-pool 31.161.18.115 prefix-length 29
ip nat pool XBOX-pool 31.161.18.116 prefix-length 29
You don't need the secondary IP addresses on
 int gi0/0/1.1
Correct config is:
int gi 0/0/1.1
I omitted the end address of the pool in the previous config. Correct is:
ip nat pool LAN-pool 31.161.18.115 31.161.18.115 prefix-length 29
ip nat pool XBOX-pool 31.161.18.116 31.161.18.116 prefix-length 29
Regards, LG
conf t
no ip access-list extended 161
remark XBOX acces denied
deny ip host 10.15.161.42 any
remark XBOX acces allowed
permit ip host 10.15.161.42 any
gonna test it when everyone sleeps
TIA
You have one SP and one WAN interface and more than one public IP?
MHM
Yes, I got a static block a /29 and only one wan interface gi 0/0/0 (shutdown) and active GPON on gi 0/0/1.1 (L2)
can do .118 and .119 too, but have no use for it (yet, maybe guest network vlan get their own IP, but is new and heaven for me)
Vlan1 is LAN and XBOX is in same Vlan as the rest of the kids gear and mine (having it in separate vlan creates problems, cuz their apps can't find the PS and XBOX anymore so nag nag nag until fixed. Xbox is mine, but nothing works because all the ports for online play were for the PS and switch with one IP)
