where I can find the internet symbol on the packet tracer
yossryhelal
Where can I find the cloud symbol that is supposed to be the internet on the packet tracer? I only found that the cloud has multi-user connection tag on it
Thank you!
Martin L
there is no connection to the Internet from PT as far as I know (or so far);  multi-user connection allows u to connect to others on local network like in classroom; that could be your ISP representation. Or use any other cloud as the Internet.
Regards, ML
**Please Rate All Helpful Responses **
M02@rt37
Hello @yossryhelal,
While it doesn't have an explicit "internet" label, the cloud symbol in Packet Tracer serves the purpose of connecting your local network to external networks, including the internet. You can use it as a representation of your network's connection to the internet.
Best regards
Hi. Thanks for this. But I have something to ask, is it also okay to use routers to represent the internet? Your answer is much appreciated.
