Cisco IOS DDR Dialer Watch-List (VRF) issues
dneggers1
Level 4
Level 4
Hi Guys,
We have a Dial Backup ISDN (DDR) configured on all our WAN Sites, with a Watch-List, in case of our WAN service Failure.
This has been working perfectly until recently when we upgraded our IOS :
From - c3845-advipservicesk9-mz.124-9.T5.bin
To - c3845-advipservicesk9-mz.124-24.t2.bin
Since this upgrade, the Watch-list command no longer works with VRF, so it is continually dialing up, even though the "Watched Route" is in the VRF Routing table.
We have proved this by watching a Route in the "Default" VRF, and it works fine.
So in Short, 124-24.t2 is bugged and does not work for the following command anymore :
dialer watch-list 1 ip 10.2.0.0 255.255.255.0 vrf DITR-DATA
Is there any extra config we need to enter for this to work on the new IOS?
Please see config & also the current "Wathced Route in the Routing table"
interface BRI0/1/0
description OnRamp2 Line Number XXXOmitted
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
load-interval 30
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
no keepalive
no fair-queue
no cdp enable
ppp authentication chap
interface Dialer1
ip vrf forwarding DITR-DATA
ip address 10.199.1.130 255.255.255.192
encapsulation ppp
dialer pool 1
dialer remote-name AC01WRT01
dialer idle-timeout 600
dialer string XXXOMITTED
dialer load-threshold 2 either
dialer watch-group 1
dialer-group 1
ppp multilink
access-list 101 deny   ospf any any
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
ITRWART1-New#  sh ip route vrf DITR-DATA 10.2.0.0
Routing entry for 10.2.0.0/24
  Known via "ospf 10", distance 110, metric 51, type intra area
  Last update from 10.199.1.1 on Tunnel0, 1w2d ago
  Routing Descriptor Blocks:
  * 10.199.1.1, from 10.200.99.3, 1w2d ago, via Tunnel0
      Route metric is 51, traffic share count is 1
Cheers
Dion
Ralph Rye
Dion,
I am experiencing the same thing, did you ever figure out a work around or a release that doesn't have this bug?
Ralph
