Cisco IOS Upgrade
johnsamuel
The Cisco IOS upgrade site is very difficult to use. With about 60 routers and about 60 switches of different models and different amounts of RAM and/or flash it makes my summer IOS upgrade take about a week and a half when it should only take a few hours.
I would like to see the Cisco IOS upgrade site changed so we could just enter the model number and get a list of available IOSes listing the IOS version, IOS file name, RAM required, flash required, and feature set. The IOS version, amount of RAM, amount of flash, and feature set should all be options that could be added with the model number on the request to shorten the list but would not be required to get the output list of available IOSes. We should be able to click on the file name from that output list to start the download process of that IOS. Also, the output list should be printable.
Any time a feature set is listed we should be able to click on that feature set name and get a detailed list of what that feature set means that also would be printable.
