Cisco ISR 1100 Series BVI Configuration Problem
The Cisco ISR 1100 Series router cannot accept the following commands, it is not like Cisco 800 series routers, what can i do?
CBE1035_00_ER1(config)#bridge irb
CBE1035_00_ER1(config)#bridge 1 protocol ieee
% Invalid input detected at '^' marker.
CBE1035_00_ER1(config)#bridge 1 route ip
Spanning Tree protocol for Bridge Group 1 has not been configured.
CBE1035_00_ER1(config)#interface ATM0/3/0
CBE1035_00_ER1(config)#no shutdown
CBE1035_00_ER1(config-if)#bridge-group 1
CBE1035_00_ER1(config)#interface BVI1
% Bridge group 1 is not configured
Here is the version of the router,
CYOUR LOGIN DETAILS HAVE BEEN CAPTURED AND LOGGED!C If you are not an authorized user, disconnect now!CBE1035_00_ER1#sh ve
CBE1035_00_ER1#sh version
Cisco IOS XE Software, Version 16.09.05
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 30-Jan-20 18:09 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
CBE1035_00_ER1 uptime is 9 hours, 16 minutes
Uptime for this control processor is 9 hours, 18 minutes
System returned to ROM by PowerOn at 10:09:19 EAT Sat May 15 2021
System restarted at 07:35:41 EAT Wed May 19 2021
System image file is "bootflash:c1100-universalk9_ias.16.09.05.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing is DISABLED
cisco C1117-4PLTEEA (1RU) processor with 1452736K/6147K bytes of memory.
Processor board ID FCZ242292L9
1 Ethernet interface
3 Virtual Ethernet interfaces
5 Gigabit Ethernet interfaces
1 ATM interface
4294966432 terminal lines
2 Cellular interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2863103K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
