Cisco ISRC1111-4P keeps booting
xtrarobson
Cisco C1111-4p Keeps rebooting.
System Bootstrap, Version 16.6(1r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
C1111-4P platform with 4194304 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
no valid BOOT image found
Final autoboot attempt from default boot device...
Located throughput_monitor_params
Unsupported package header version (-1347440721)
Located pnp-tech-time
Located pnp-tech-discovery-summary
Unsupported package header version (542470260)
Located start.txt
Unsupported package header version (544235891)
Failed to find bootable image on device bootflash:
autoboot: boot failed, restarting...
Resetting .......
Rom image verified correctly
Resetting .......
Located start.txt
Resetting .......
Resetting .......
Rommon etc is not starting up cant hit up any commant. any ideas?
xtrarobson
No IOS on router and password recovery is disabled
Leo Laohoo
NO VALID IOS found in the router.
Really dumb move to disable password recovery.
With password recovery disabled the router will continuously go into a boot loop. If forcing/breaking the router into ROMMON, this will cause the configuration to be erase.
