11-30-2017 10:23 PM - edited 03-05-2019 09:34 AM
1. username cisco privilege 0~15 -> Why there are total 16 levels of privilege? Because I can only set up one username and one password right?
2. Is there a way to encrypt username?
3.
User Mode -> Privileged Mode --- Password: Cisco
line console 0 -> Username: Pencil, Password: Case
line vty 0 4 -> Username: Telnet, Password: Ssh
-> Is there a way to configure the username and password like that and encrpyt all usernames and passwords?
Solved! Go to Solution.
12-01-2017 12:10 AM
you can actually create as many users as you want, and assign different privilege levels:
username admin1 privilege 1 password 0 adminone
username admin2 privilege 2 password 0 admintwo
username admin3 privilege 3 password 0 adminthree
You cannot encrypt the username.
For your console and VTY access, create a local username and specify that you want to use local login on those lines:
username Pencil privilege 15 password 0 Cisco
username Telnet privilege 15 password 0 Ssh
line con 0
login local
line vty 0 4
login local
12-01-2017 12:10 AM
line con 0
login local
line vty 0 4
login local
12-01-2017 12:27 AM - edited 12-01-2017 12:34 AM
BTW, I can access console and VTY using both Pencil and Telent username right?
-> What does password 0 or 7 mean?
0 Specifies an UNENCRYPTED password will follow
7 Specifies a HIDDEN password will follow
-----> Aftering reading descriptions, still don't get it :(
