Dear all,
i have Cisco Prime Infrastructure 2.2 on which installed all fix patches and device pack, but i faced some problems:
1-i divide my network to some locations where as different sites, i need to know how to display the connected physical link between the sites to be appeared in the network map in cisco PI GUI ?
2- one of the sites i configured, the physical connection between the BB switch and another edge switch is not appeared while all the other physical connections are appeared normally, please advice what may be the issue ?
note that,
from inventory >>> network devices >>> i can see the above edge switch as long as the BB switch as managed and completed inventory collection
in the network devices summary.
thanks in advance.
Appreciation.
