Cisco Router 1800/Cisco Switch 2960 Access List Help !!!!!!!!!!!!
j_j624001
Hello;
I need some help on securing certain ports in/out my network
So i tried and tried and tried different configurations difference scenriaos far as my access-list to allow only certain ports in and out.
What i would like to do on my outside interface is have only port 7,53, 80, 443, and 8080 allowed; where as my inside internal interface i would like to have port 7,21,22,23,25,53,67,80,110,123,143,443,1500,1501, and 8080; yes i know ports by the back of my head and these are the only port i want to be allowed inside my interface so all my computers/servers can talk/share/ping/ftp etc etc to each other.
Any ideas that could help ??
44 Replies 44
Share your configuration
Building configuration...
Current configuration : 2607 bytes
! Last configuration change at 02:08:45 UTC Sat Dec 19 2015 by JJ
! NVRAM config last updated at 02:01:35 UTC Sat Dec 19 2015 by JJ
version 12.4
service config
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
clock calendar-valid
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.0.3 10.10.0.99
ip dhcp excluded-address 10.10.0.150 10.10.0.255
ip dhcp pool R_POOL
   import all
   network 10.10.0.0 255.255.255.0
   update dns
   default-router 10.10.0.1
   dns-server 192.168.0.1 8.8.8.8 8.8.4.4 4.2.2.4
   domain-name R.com
   update arp
ip domain name T-Net.com
ip ssh version 2
interface FastEthernet0
 description OUT
 ip address 192.168.0.X 255.255.255.0
 ip access-group filter-inbond in
 ip access-group filter-outbond out
 ip nat outside
 ip virtual-reassembly
 speed 100
 full-duplex
interface FastEthernet1
 description LAN
 ip address 10.10.0.1 255.255.255.0
 ip nat inside
 speed 100
 full-duplex
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
no ip http secure-server
ip nat inside source list 50 interface FastEthernet0 overload
access-list 50 permit 10.10.0.0 0.0.255.255
That should work
Add these commands to your current configuration.
ip access-list extended filter-inbond
  permit udp any eq domain any
  permit icmp any any echo-reply
  evaluate CHECK-TRAFFIC
  deny ip any any
ip access-list extended filter-outbond
 permit tcp any any eq www reflect CHECK-TRAFFIC
 permit tcp any any eq 443 reflect CHECK-TRAFFIC
 permit tcp any any eq 8080 reflect CHECK-TRAFFIC
 permit udp any any eq domain
 deny   ip any any
Try ping and browse some sites.
That time copy the entire configuration and then post it. Then also post output of this command
show access-lists
Ok; when i try to go to access the websites like google, yahoo, wellsfargo,ebay  i still get "This page can’t be displayed"
i can ping
R1#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
R1#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/28/32 ms
R1#ping 8.8.4.4
Sending 5, 100-byte ICMP Echos to 8.8.4.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/29/32 ms
R1#ping 4.2.2.4
Sending 5, 100-byte ICMP Echos to 4.2.2.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/31/40 ms
Show access-lists
Standard IP access list 50
    10 permit 10.10.0.0, wildcard bits 0.0.255.255 (14866 matches)
Reflexive IP access list CHECK-TRAFFIC
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52451 (89 matches) (time left 248)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52450 (17 matches) (time left 247)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52449 (97 matches) (time left 248)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52448 (91 matches) (time left 248)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52447 (151 matches) (time left 248)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52446 (103 matches) (time left 248)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52445 (79 matches) (time left 247)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52444 (127 matches) (time left 247)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52443 (133 matches) (time left 247)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52442 (127 matches) (time left 247)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52441 (67 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52440 (73 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52439 (109 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52438 (97 matches) (time left 247)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52437 (53 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52436 (109 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52435 (115 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52434 (115 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52433 (17 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52432 (65 matches) (time left 255)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52431 (17 matches) (time left 246)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52430 (47 matches) (time left 246)
     permit tcp host 216.58.219.142 eq www host 192.168.0.80 eq 52427 (55 matches) (time left 242)
     permit tcp host 72.21.91.8 eq www host 192.168.0.80 eq 52424 (149 matches) (time left 246)
     permit tcp host 216.58.219.104 eq www host 192.168.0.80 eq 52407 (277 matches) (time left 229)
Extended IP access list filter-inbond
    10 permit udp any any eq domain
    20 permit icmp any any echo-reply (105 matches)
    30 evaluate CHECK-TRAFFIC
    40 deny ip any any (1568 matches)
Extended IP access list filter-outbond
    10 permit tcp any any eq www reflect CHECK-TRAFFIC (7950 matches)
    20 permit tcp any any eq 443 reflect CHECK-TRAFFIC (211 matches)
    30 permit tcp any any eq 8080 reflect CHECK-TRAFFIC
    40 permit udp any any eq domain (954 matches)
    50 permit icmp any any echo
    60 deny ip any any (60 matches)
Current Configuration
R1#s
Current configuration : 3048 bytes
! Last configuration change at 02:31:00 UTC Sat Dec 19 2015 by JJ
! NVRAM config last updated at 02:25:23 UTC Sat Dec 19 2015 by JJ
version 12.4
service config
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
ip dhcp pool R_POOL
   import all
   update dns
   domain-name R.com
   update arp
ip ssh version 2
 description OUT
 ip address 192.168.0.80 255.255.255.0
 ip nat outside
 speed 100
 full-duplex
 description LAN
 ip nat inside
 speed 100
no ip http server
 deny   ip any any
 deny   ip any any
If the result was the same, try this one. Remember to remove them all at first. I need to figure out the problem.
 deny ip any any
permit  ip any any reflect CHECK-TRAFFIC
 description OUT
Let me know to give you another configuration if none of those worked. I implemented your scenario myself on 2800 router. It is working here. I have the same configuration as you have.
Remove all and try this one instead. give me your feedback.
  deny ip any any
 permit   ip any any
 description OUT
Ok;
So here's what i done to be testing; once i had all your configurations i tried 4 differnet website still same error msg as stated earlier. Once i started deleting the inbond rules one by one and refreshing my website still same error msg; but once the inboud rules was empty and clear i was able to see all my 4 website as there were refresh.
Current configurations
Current configuration : 2942 bytes
! Last configuration change at 03:22:24 UTC Sat Dec 19 2015 by JJ
! NVRAM config last updated at 03:22:25 UTC Sat Dec 19 2015 by JJ
version 12.4
service config
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
ip dhcp pool R_POOL
   import all
   update dns
   domain-name R.com
   update arp
ip ssh version 2
 description OUT
 ip nat outside
 speed 100
 full-duplex
 description LAN
 ip nat inside
 speed 100
 full-duplex
no ip http server
 deny   ip any any
    10 permit tcp any any eq www reflect CHECK-TRAFFIC (15738 matches)
    20 permit tcp any any eq 443 reflect CHECK-TRAFFIC (8433 matches)
    40 permit udp any any eq domain (789 matches)
    60 deny ip any any (4 matches)
Let me give you another configuration. Forget other configuration. Try this one. make sure you remove everything at first.
  permit tcp any eq www any   established
  permit tcp any eq 443 any   established
  permit tcp any eq 8080 any  established
  deny ip any any
 deny   ip any any
 description OUT
Give your feedback.
Nope didn't work !!! once everything was removed and configurations was added; it didn't work ; pages still get unable to be displayed even when refresh or searching misc sites; once all inbond rules are removed and only works with the outbond rules are enable it works for searching misc sites; and i just tried for testing these two inbond rules (permit icmp any any echo-reply; permit tcp any eq 8080 any  established on inbond rules; still getting page not displayed with searching misc.........maybe the outbound interface is catching pkts from the ISP; cause i know i don't have any port forwarding on the isp enable... idk
It is wired. Just try the below configuration one more time and list the output of this command. I have the same configuration here. It is working for me.
  deny ip any any
 deny   ip any any
 description OUT
show access-list
Yes it is weird; maybe it has something to do with the access list 50; idk; strange; still same error message
    10 permit 10.10.0.0, wildcard bits 0.0.255.255 (4583 matches)
    20 permit icmp any any echo-reply (4 matches)
    30 permit tcp any eq www any established (36 matches)
    40 permit tcp any eq 443 any established (102 matches)
    50 permit tcp any eq 8080 any established
    60 deny ip any any (1278 matches)
    10 permit tcp any any eq www (16866 matches)
    20 permit tcp any any eq 443 (15264 matches)
    40 permit udp any any eq domain (3742 matches)
    50 permit icmp any any echo (5 matches)
    60 deny ip any any (53 matches)
edited
ok; well looks like it still didn't work; i check to make sure my computer firewall was disable which it was; i've search search search different sites still nothing with the inbond rules enable. see below access-list the first is when i just added configuration; second is when i was searching misc sites.
1.
    10 permit 10.10.0.0, wildcard bits 0.0.255.255 (6609 matches)
    110 permit tcp any eq www any established
    120 permit tcp any eq 443 any established (3 matches)
    130 permit tcp any eq 8080 any established
    140 deny ip any any (4 matches)
    10 permit tcp any any eq www (19786 matches)
    20 permit tcp any any eq 443 (22022 matches)
    40 permit udp any any eq domain (8869 matches)
    60 deny ip any any (56 matches)
2.
    10 permit 10.10.0.0, wildcard bits 0.0.255.255 (7048 matches)
    110 permit tcp any eq www any established (10 matches)
    120 permit tcp any eq 443 any established (117 matches)
    140 deny ip any any (1754 matches)
    10 permit tcp any any eq www (19804 matches)
    20 permit tcp any any eq 443 (22114 matches)
    40 permit udp any any eq domain (10180 matches)
try this one. I made a change. Remove everything. I had overlooked something.
  deny ip any any
 deny   ip any any
 description OUT
