cisco router 3620
hugh.lancaster
I guess i am in the correct forum. My cisco 3620 lab computer does not have an IOS that allows me to practive with SDM aleast I could not find the correct IOS.
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(29b
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Lucien Avramov
Level 10
Level 10
SDM 2.5 does support 3620 as per the release notes:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/software/release/notes/SDMr25.html
You need to run on it:
•12.2(11)T6 or later releases
•12.3(1)M or later releases
You have enough memory to install SDM express or install SDM on the computer once you upgraded to a version that has proper support for HTTP.
What IOS will support HTTP for this router? I have installed on computer but the current IOS does not support Https and IOS I have found are to large. thanks
hugh.lancaster
