Cisco Router 4221 - IP SLA ICMP-echo
karlmaestrado
Hi to cisco community,
I would like to ask, Is there someone used the IP SLA icmp-echo in router 4221? Do we need a license to use it?
way back cisco 1900 to be able to use IP SLA echo, it's require to purchased Data license. same to 4221?or 4000 series?
Thanks!
2 Accepted Solutions
Seb Rupik
Hi there,
The DATA license and contained features (including IP SLA) has been replaced by the AppX license.
Application Experience (AX)
IP Base + Security + advanced networking protocols: L2TPv3, BFD, MPLS, VRF, VXLAN[10](Bandwidth <100Mbps)
Application Experience: PfRv3, WAAS with AppNav, NBAR2, AVC, IP SLA
Hybrid Cloud Connectivity: LISP, OTV (for Bandwidth <100Mbps), VPLS, EoMPLS
Intelligent Web Caching: Akamai Connect
See table 5 :
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
cheers,
Seb.
Yes, it is not included as part of IP Base.
cheers,
Seb.
Seb Rupik
Hi there,
See table 5 :
cheers,
Seb.
So I need to purchase this AppX License to be able to use the IP SLA?
cheers,
Seb.
Thank you!
