Cisco Router 4321 bandwidth limit
Hi All,
Cisco Router 4321 - does support up to maximum how much bandwidth ? Also how to check that ?
Please advise.
6 Replies 6
jmperlewitz
Hi Ganesh,
The 4321 supports up to 50 Mbps.  However, you can get a license upgrade so it can support 100 Mbps.
You can check the throughput by issuing the following command:  sh platform hardware throughput level
Check out this useful link: https://www.cisco.com/c/en_in/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
tiimup
Please how do i make it support 200 Mbps? I currently use it for a 200 Mbps link but it is out putting only 50 Mbps.
For more than 100 Mbps you need a boost license, which may allow up to 1.5 Gbps.
Hi Joseph,
Many thanks for the response. But who do i reach out to for this license upgrade for a 200Mbps link? Can you share a contact, an email address?
Any authorized Cisco retailer/dealer, or possibly Cisco itself.
Ok. Great.
Many Thanks
