Cisco Router access outside interface from inside LAN
Yura Kazakevich
Hello everyone!
I have Cisco Router 892 (c890-universalk9-mz.154-3.M4.bin) with Zone-Based Firewall and Policy-based routing.
Everything works fine, but now I need to have ability access outside router interface IP adresses from LAN.
For example, I have PAT from 192.168.4.1 port 8443 to outside interface IP (93.93.93.2 for example) and I need to check 93.93.93.2:8443 from LAN.
! PAT:
ip nat inside source static tcp 192.168.4.1 8443 93.93.93.1 8443 route-map SDM_RMAP_1 extendable
! DynNat to internet:
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0 overload
! Policy-routing
route-map SDM_RMAP_1 permit 10
 match ip address 101
 match interface GigabitEthernet0
! ACL 101 for Policy-routing
access-list 101 deny   ip 192.168.3.0 0.0.0.255 192.168.111.0 0.0.0.255
access-list 101 deny   ip 192.168.3.0 0.0.0.255 172.16.192.0 0.0.0.255
access-list 101 deny   ip 192.168.3.0 0.0.0.255 172.16.177.0 0.0.0.255
access-list 101 deny   ip 192.168.3.0 0.0.0.255 172.16.61.0 0.0.0.255
access-list 101 deny   ip 192.168.3.0 0.0.0.255 172.17.19.0 0.0.0.255
access-list 101 deny   ip 192.168.4.0 0.0.0.255 192.168.111.0 0.0.0.255
access-list 101 deny   ip 192.168.3.0 0.0.0.255 host 172.16.194.100
access-list 101 deny   ip 192.168.3.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 deny   ip 192.168.4.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 deny   ip 192.168.4.0 0.0.0.255 host 172.31.255.1
access-list 101 deny   ip 192.168.4.0 0.0.0.255 host 172.16.194.100
access-list 101 permit ip 192.168.3.0 0.0.0.255 any
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
! ACL on outside interface:
ip access-list extended gi0-in
 permit ip any any
 permit icmp any any
! Outside interface
 description $ETH-WAN$
 ip address 93.93.93.1 255.255.255.240
 ip access-group gi0-in in
 ip nat outside
 ip virtual-reassembly in
 zone-member security WAN
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 crypto map SDM_CMAP_2
! Inside DMZ interface-vlan:
interface Vlan4
 ip address 192.168.4.254 255.255.255.0
 ip nat inside
 zone-member security DMZ
! Allow outgoing traffic from DMZ to Internet:
ip access-list extended Allow_All_ACL-DMZ
 permit esp any any
 permit tcp host 192.168.4.1 host 192.168.111.2 eq 1521
 deny   ip 192.168.4.0 0.0.0.255 172.17.19.0 0.0.0.255
 permit icmp 192.168.4.0 0.0.0.255 any
! Allow ingoing traffic from Internet to DMZ:
ip access-list extended WAN_DMZ_ACL
 permit tcp any any established
 permit tcp any any eq ftp
 permit tcp any any eq 990
 permit tcp any any range 51000 53000
 permit tcp any any eq 995
 permit tcp any any eq 465
 permit tcp any any eq www
 permit tcp any any eq 443
 permit icmp any any
 permit esp any any
 permit udp any any eq non500-isakmp
 permit ip host 212.98.162.139 192.168.4.0 0.0.0.255
 permit ip 81.30.80.0 0.0.0.255 any
 permit ip 192.168.111.0 0.0.0.255 192.168.4.0 0.0.0.255
 permit ip 172.17.19.0 0.0.0.255 192.168.4.0 0.0.0.255
 permit ip host 172.16.194.100 192.168.4.0 0.0.0.255
 permit ip host 172.31.255.1 192.168.4.0 0.0.0.255
 permit ip host 172.31.255.1 host 172.17.193.100
 deny   ip any any
! Zone-Based Firewall:
class-map type inspect match-any DMZ_WAN_CLASS
 match access-group name Allow_All_ACL-DMZ
class-map type inspect match-any WAN_DMZ_CLASS
 match access-group name WAN_DMZ_ACL
policy-map type inspect DMZ_WAN_POLICY
 class type inspect DMZ_WAN_CLASS
  inspect
 class class-default
  drop
policy-map type inspect WAN_DMZ_POLICY
 class type inspect WAN_DMZ_CLASS
  inspect
 class class-default
  drop
zone security DMZ
zone security WAN
zone-pair security WAN_DMZ source WAN destination DMZ
 service-policy type inspect WAN_DMZ_POLICY
zone-pair security DMZ_WAN source DMZ destination WAN
 service-policy type inspect DMZ_WAN_POLICY
May be somebody can help me make Cisco to allow outside NATed ports from LAN?
I made this on Mikrotik easily =|
It's due to the fact they do not allow 'hair pinning' by default, once this is configured it will work.
Martin
Yura Kazakevich
UP!
Access to router's outside interface from inside LAN..
Why it's so difficult on cisco routers, ASA and PIX????(
Martin
I really appreciate for your reply, Martin Carr!
Tonight I tried to setup Hairpinning (based on NVI) as discribed here. Then I needed to remake NAT rules from this (examlpe):
ip nat inside source static tcp 192.168.4.1 22 7.10.20.30 22 route-map SDM_RMAP_1 extendable
to this:
ip nat source static tcp 192.168.4.1 22 7.10.20.30 22 extandable
I cannot use Policy-routing in NVI NAT =( So I can access 7.10.20.30:22 from LAN, but now I  unable to access 192.168.4.1:22.
192.168.4.0/24 it's DMZ zone, I checked it drom LAN zone 192.168.3.0/24.
