Cisco Router can't get out to the internet behind a Comcast Modem
CorporateITGuy
I am brand new to all things Cisco so apologies for any dumb questions or inability to grasp basic concepts. Trying to set up a cisco router, C897VA-K9, and for some reason I can't even ping dns.google.com from the router with a:
#ping 8.8.8.8
any ideas why? or troubleshooting steps that I can take to figure out what's going on?
Thanks!
add the lines marked in bold to your configuration:
Cisco#show run
Building configuration...
Current configuration : 1996 bytes
! Last configuration change at 16:41:34 UTC Tue Sep 21 2021 by corporate
version 15.4
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
cts logging verbose
license udi pid C897VA-K9 sn FGL220992H6
username [removed]
controller VDSL 0
crypto isakmp policy 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
interface Vlan20
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
--> ip nat inside source list 1 interface GigabitEthernet8 overload
--> access-list 1 permit 192.168.1.0 0.0.0.255
--> access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
8 Replies 8
post the full running configuration (show run) of your router...
Cisco#show run
version 15.4
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
username [removed]
controller VDSL 0
interface ATM0
 no ip address
 shutdown
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
interface Ethernet0
 no ip address
 shutdown
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan10
 ip nat inside
interface Vlan20
 ip nat inside
ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 3
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
end
Thanks for the quick reply, sorry it took so long.
Cisco#show run
version 15.4
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
username [removed]
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Thank you so much! Can you explain to me what those lines did?
I think this one just made it possible for traffic to get out of the router through g8 right?
This one I'm not really sure about
and these 2 allow traffic to leave the VLANs right?
Just trying to understand here, thanks again!
exactly. The access lists make sure that the NAT process knows which IP addresses it needs to translate, and the default route sends all traffic out the interface connected to the ISP modem.
If I wanted to assign a specific IP address as opposed to using DHCP. For example say I have the WAN IP address of 50.50.50.50 and I want all outbound traffic to show like its coming from that address as opposed to the modems 50.50.50.49 like it is with the current configuration. How would I go about that? I would have to edit the static route right?
in that case, you need to change the default route to the next hop. Necessary changes are marked in bold:
Cisco#show run
version 15.4
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
username [removed]
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
--> ip address 50.50.50.50 255.255.255.252
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
ip http server
--> ip route 0.0.0.0 0.0.0.0 50.50.50.49
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Tried posting this in a different thread and I’m not getting any results so I am going to add it on to the end here in case someone can help me. ( here’s a link the the where I posted the question: https://community.cisco.com/t5/routing/assign-outbound-ips-and-direct-inbound-traffic/td-p/4471649 )
need to assign outbound ip addresses and direct inbound traffic.
outbound ip addresses: for example my modem is 50.50.50.50, my router is assigned 50.50.50.51, and I have webserver on 192.168.10.10 in a VLAN that I would like to assign to 50.50.50.52. This would be done with a static route correct?
Direct Inbound Traffic: for example traffic attempting to get to this webserver coming in on 50.50.50.52 on the https port (port # 443) should go to 192.168.10.10 in lets say VLAN 10. This would be another static route wouldn't it?
Thank you for any and all help!
