Cisco router configuration for public ip
Aronamaha
I want to config. my Cisco 1941 router to
1. enable my LAN users to access internet
2. make my web server 192.168.1.100 255.255.255.0 live from internet,
my ISP gave me this
wan ip 10.136.65.150
subset mask 255.255.255.252
gateway 10.136.65.146
and public IP address 196.190.29.81 and 196.190.29.82 (for my web server)
internet is working using my tplink router using the wan ip (not the public ip )
7 Replies 7
Alan Ng'ethe
Level 3
Level 3
access-list 100 permit 192.168.1.0 0.0.0.255 any
ip nat inside source static 192.168.1.100 https  196.190.29.82 https
my ISP gave me this
interface (whatever interface on your router will be the wan interface)
e.g.
interface GigabitEthernet0/1
ip address 10.136.65.150 255.255.255.252
no shut
ip nat outside
And for the LAN interface;
interface GigabitEthernet0/0
ip address 192.168.1.0 255.255.255.250
no shut
ip nat inside
ip nat pool internetPool 196.190.29.81 196.190.29.81 netmask 255.255.255.255
ip route 0.0.0.0 0.0.0.0 10.136.65.146
ip nat inside source list 100 pool internetPool overload
Having said that, your public ip and gateway seem to be inconsistent. Please verify those details with your ISP. Once you have consistent ip and mask you may make the changes as suggested above.
The valid range for your WAN network is 10.136.65.148 through 10.136.65.151. Your gateway is .146, placing it in a totally different subnet. You will need to correct that before any configurations can begin.
Remember to rate any posts that have been helpful.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
thanks !!! but why do i need netmask 255.255.255.255 in the "ip nat pool internetPool 196.190.29.81 196.190.29.81 netmask 255.255.255.255 ? "
/32 netmask is used because the pool has one address, which basically makes it PAT. The other of your two addresses is consumed by the static nat to the web server.
Please rate any posts that have been
elpful.
my ISP gave me this
This is incorrect addressing
10.136.65.148/30incorporates usable ip addresses of:
10.136.65.149
10.136.65.150
not 10.136.65.146
So am I assuming this is typo?
Kind Regards
Paul
yes it was a typo sir , my gateway from ISP is 10.136.65.149 ! thanks .
so can you help me in the configuration !
Hello
Then you nat configuration would be
access-list 1 permit 192.168.1.0 9.0.0.255
ip nat inside source-list 1 interface (wan)
ip nat inside source static tcp 192.168.1.100 80 10.36.65.150 80 extendable
Kind Regards
Paul
since you have two additional public IP addresses, you could assign one of the IP addresses to the web server, that way you would not even need to NAT. Use one of the IP addesses for the server, and the other as the default gateway on your subinterface:
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.2
encapsulation dot1q 2
ip address 196.190.29.81 255.255.255.252
duplex auto
speed auto
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
ip forward-porotocol nd
ip http server
no ip http secure-server
line con 0
no activation-character
line vty 0 4
login local
end
