Cisco router Ipsec tunnel to Juniper SRX routing issue
TRACY HARTMANN
I have a tunnel setup between a cisco router and a Juniper SRX.   The tunnel actually up but I can't route over it.
The route is setup to go to the next hop for the gateway
192.168.16.0 255.255.255.0 Public IP of the gateway
I am also seeing hits on that subnet but I can't ping across
Francesco Molino
What do you see when running show crypto ipsec sa ?
Do you see any encrypt and decrypt hits?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
post the full configs of the IOS router (sh run) and the SRX (show | display set)...
