How to check which snmp servers and flow-export are inactive (not in use) or have no counters traffic
getaway51
Level 2
Level 2
cm3dgbr# snmp-server host 192.168.2.33 version 2c read
cm3dgbr #ip flow-export destination 192.168.1.4 7775
Giuseppe Larosa
Hello getaway51,
both SNMP in sending traps and netflow export use UDP that is connectionless.
This means the device will send traps for configured destination and netflow flow exports packets if it is able to route packets to respective destinations (including use of a default route). No feedback is expected from servers.
In order to understand if these servers are still operational you should contact the colleagues that manage them.
Hope to help
Giuseppe
is there any command to see the stats like snmp/flow traffic being send out?
for snmp
show snmp
should be enough look at SNMP traps sent counter.
for netflow
show ip flow export
should provide the desired info
However, the fact that these counters are non zero do not mean that the respective servers are actually working and listening on respective UDP ports as I explained in my previous post.
Hope to help
Giuseppe
