10-27-2021 04:43 AM
Hi everyone,
I finally have managed to set up my Cisco C1111X-8P router for production use (thanks to everyone involved!). However, when I perform a speed test (www.speedtest.net) on my 1Gbit/s line, I can only manage to get around 500-600 Mbit/s. The ISP says the line is fine and my old router (Ubiquiti) easily managed to get ahold of 940Mbit/s. During the speedtest, the QFP processing load goes up to 20%, so I do think the hardware should be able to handle that.
I will post my running-config below, maybe there is something there that is misconfigured (the whole DSCP stuff was added by the WebGUI, maybe remove that?)
Thanks!
version 17.6
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname CiscoRouter
boot-start-marker
boot system bootflash:c1100-universalk9.17.06.01a.SPA.bin
boot system bootflash:c1100-universalk9.17.05.01a.SPA.bin
boot-end-marker
no aaa new-model
clock timezone GMT 1 0
ip nbar http-services
ip name-server 8.8.8.8 8.8.4.4
ip domain name localdomain.local
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
lease 7
login on-success log
subscriber templating
no license feature hseck9
license udi pid C1111X-8P sn XXXXXX
license boot level securityk9
license smart transport callhome
memory free low-watermark processor 73242
diagnostic bootup level minimal
redundancy
mode none
vlan internal allocation policy ascending
class-map match-all WEBUI-MULTIMEDIA_CONFERENCING-DSCP
match dscp af41
class-map match-all WEBUI-BROADCAST_VIDEO-NBAR
match protocol attribute traffic-class broadcast-video
match protocol attribute business-relevance business-relevant
class-map match-all WEBUI-VOICE-NBAR
match protocol attribute traffic-class voip-telephony
class-map match-all WEBUI-BULK_DATA-NBAR
match protocol attribute traffic-class bulk-data
class-map match-all WEBUI-SIGNALING-NBAR
match protocol attribute traffic-class signaling
class-map match-all WEBUI-NETWORK_CONTROL-DSCP
match dscp cs6
class-map match-all WEBUI-SCAVENGER-NBAR
match protocol attribute business-relevance business-irrelevant
class-map match-all WEBUI-SCAVENGER-DSCP
match dscp cs1
class-map match-all WEBUI-NETWORK_CONTROL-NBAR
match protocol attribute traffic-class network-control
class-map match-all WEBUI-SIGNALING-DSCP
match dscp cs3
class-map match-all WEBUI-BULK_DATA-DSCP
match dscp af11
class-map match-all WEBUI-BROADCAST_VIDEO-DSCP
match dscp cs5
class-map match-all WEBUI-MULTIMEDIA_CONFERENCING-NBAR
match protocol attribute traffic-class multimedia-conferencing
class-map match-all WEBUI-VOICE-DSCP
match dscp ef
class-map type inspect match-any DHCP_app
match protocol udp
match protocol bootpc
class-map type inspect match-any Allow_DHCP_app
match protocol udp
class-map match-all WEBUI-NETWORK_MANAGEMENT-NBAR
match protocol attribute traffic-class ops-admin-mgmt
class-map match-all WEBUI-MULTIMEDIA_STREAMING-DSCP
match dscp af31
class-map match-all WEBUI-REALTIME_INTERACTIVE-NBAR
match protocol attribute traffic-class real-time-interactive
class-map match-all WEBUI-TRANSACTIONAL_DATA-DSCP
match dscp af21
class-map match-all WEBUI-REALTIME_INTERACTIVE-DSCP
match dscp cs4
class-map type inspect match-any IN-TO-OUT
match access-group name IN-TO-OUT_acl
match protocol http
match protocol ftp
match protocol icmp
match protocol https
match protocol dns
match protocol smtp
match protocol pop3
match protocol tcp
match protocol udp
class-map type inspect match-all INSIDE_TO_OUTSIDE
match access-group name INSIDE_TO_OUTSIDE_acl
class-map match-all WEBUI-TRANSACTIONAL_DATA-NBAR
match protocol attribute traffic-class transactional-data
class-map match-all WEBUI-NETWORK_MANAGEMENT-DSCP
match dscp cs2
class-map match-all WEBUI-MULTIMEDIA_STREAMING-NBAR
match protocol attribute traffic-class multimedia-streaming
class-map match-any DHCP_nbar_app
match protocol dhcp
class-map match-any Allow_DHCP_nbar_app
match protocol dhcp
class-map type inspect match-all Allow_DHCP
match class-map Allow_DHCP_app
match access-group name Allow_DHCP_acl
class-map type inspect match-all DHCP
match class-map DHCP_app
match access-group name DHCP_acl
policy-map WEBUI-MARKING-IN
class WEBUI-VOICE-NBAR
set dscp ef
class WEBUI-BROADCAST_VIDEO-NBAR
set dscp cs5
class WEBUI-REALTIME_INTERACTIVE-NBAR
set dscp cs4
class WEBUI-MULTIMEDIA_CONFERENCING-NBAR
set dscp af41
class WEBUI-MULTIMEDIA_STREAMING-NBAR
set dscp af31
class WEBUI-SIGNALING-NBAR
set dscp cs3
class WEBUI-NETWORK_CONTROL-NBAR
set dscp cs6
class WEBUI-NETWORK_MANAGEMENT-NBAR
set dscp cs2
class WEBUI-TRANSACTIONAL_DATA-NBAR
set dscp af21
class WEBUI-BULK_DATA-NBAR
set dscp af11
class WEBUI-SCAVENGER-NBAR
set dscp cs1
class class-default
set dscp default
policy-map type inspect avc Allow_DHCP_app_policy
class Allow_DHCP_nbar_app
allow
class class-default
allow
policy-map type inspect avc DHCP_app_policy
class DHCP_nbar_app
allow
class class-default
allow
policy-map type inspect OUTSIDE-SELF-POLICY
class type inspect DHCP
inspect
service-policy avc DHCP_app_policy
class class-default
drop log
policy-map WEBUI-QUEUING-OUT
class WEBUI-VOICE-DSCP
priority percent 10
class WEBUI-BROADCAST_VIDEO-DSCP
priority percent 10
class WEBUI-REALTIME_INTERACTIVE-DSCP
priority percent 13
class WEBUI-NETWORK_CONTROL-DSCP
bandwidth percent 2
class WEBUI-SIGNALING-DSCP
bandwidth percent 2
class WEBUI-NETWORK_MANAGEMENT-DSCP
bandwidth percent 3
class WEBUI-MULTIMEDIA_CONFERENCING-DSCP
bandwidth percent 10
fair-queue
random-detect dscp-based
class WEBUI-MULTIMEDIA_STREAMING-DSCP
fair-queue
class WEBUI-TRANSACTIONAL_DATA-DSCP
fair-queue
class WEBUI-BULK_DATA-DSCP
bandwidth percent 4
fair-queue
class WEBUI-SCAVENGER-DSCP
bandwidth percent 1
class class-default
bandwidth percent 25
fair-queue
policy-map type inspect INSIDE-OUTSIDE-POLICY
class type inspect INSIDE_TO_OUTSIDE
inspect
class class-default
drop log
policy-map type inspect SELF-OUTSIDE-POLICY
class type inspect Allow_DHCP
inspect
service-policy avc Allow_DHCP_app_policy
class class-default
drop log
zone security INSIDE
description Zone for inside interfaces
zone security OUTSIDE
description Zone for outside interfaces
zone security default
zone-pair security INSIDE-OUTSIDE source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-OUTSIDE-POLICY
zone-pair security OUTSIDE-SELF source OUTSIDE destination self
service-policy type inspect OUTSIDE-SELF-POLICY
zone-pair security SELF-OUTSIDE source self destination OUTSIDE
service-policy type inspect SELF-OUTSIDE-POLICY
interface GigabitEthernet0/0/0
ip dhcp client client-id ascii FXXXXX
ip address dhcp
ip nbar protocol-discovery
ip nat outside
zone-member security OUTSIDE
negotiation auto
service-policy input WEBUI-MARKING-IN
service-policy output WEBUI-QUEUING-OUT
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
zone-member security INSIDE
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip forward-protocol nd
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
ip access-list extended Allow_DHCP_acl
10 permit ip any any
ip access-list extended DHCP_acl
ip access-list extended IN-TO-OUT_acl
ip access-list extended INSIDE_TO_OUTSIDE_acl
ip access-list standard 1
11 permit 192.168.1.0 0.0.0.255
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
10-27-2021 06:04 AM - edited 10-27-2021 06:05 AM
Try fast.com do you have any performance License on this router.
i would suggest to test plain vanilla config, rather more QOS config.
here some testing Cisco post :
=====️ Preenayamo Vasudevam ️=====
10-27-2021 07:15 AM
10-27-2021 07:37 AM
sure try torrents see if you get more bandwidth.
10-27-2021 12:58 PM
Hello
throughput restrictions is usually down to licensing-
show platform hardware throughput level
show platform hardware throughput-monitor parameters
10-27-2021 08:51 PM
10-27-2021 12:27 PM
the ZBF definitely impacts the throughput. What do you get when you disable it ?
--> no zone-pair security OUTSIDE-SELF source OUTSIDE destination self
--> no zone-pair security SELF-OUTSIDE source self destination OUTSIDE
ip dhcp client client-id ascii XXXXX
ip address dhcp
ip nat outside
--> no zone-member security OUTSIDE
negotiation auto
--> no zone-member security INSIDE
interface Vlan1
ip nat inside
