Cisco Router not using configured privilege level
agchapman
Hi all, (all names etc are changed)
One of our clients is using a 2811 with only one account configured, as such:
username bdmin privilege 15 secret wordpass
and the enable password configured, in the running-config as:
enable secret 5 $1$mE92$SKx0DXmiCyPIWI/170LJE1
(I know this password, its just encrypted for accuracy)
"service password-encryption" has been turned on.
However, when logging in by telnet, using the bdmin username and password, I am dropped to a user mode prompt, not a Privileged. I have tried removing and re-adding the user account. It's the only one on the router, and removing the enable secret password just leaves me stuck in user mode.
I'm running 12.3(14)T5 code and can't work out for the life of me how to get a priv 15 user login working properly. Any ideas people?
Cheers!
Hi Subeh,
I agree with you.
If aaa new-model is configured this should do the trick:
aaa authorization exec default local
Otherwise Paul solution would be ok too but with aaa new-model disabled.
Alain
19 Replies 19
Rolf Fischer
Level 9
Level 9
could you post the configuration of the line vtys?
Do you have "aaa new-model" enabled? If so, do you need AAA?
Rolf
line vty config is:
line vty 0 4
exec-timeout 20 0
transport input telnet
line vty 5 15
exec-timeout 20 0
aaa new-model has been activated, but there doesn't seem to be any aaa configured really.
Hi Alistair,
You have privilege 15 configured for username bdmin and hence you're been dropped at privilege mode. If you want to be dropped to user mode then try configuring privilege 1 instead of 15:
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a008009465c.shtml
Subeh
No, the problem is I am dropped to user mode, NOT privileged mode. I can only access privileged mode using the enable password, as I stated in the original topic.
Alistair,
Sorry, my bad. You mentioned about AAA being configured. Since there is no aaa configuration, have you tried logging in after doing 'no aaa new-model'? if yes, then what is the result?
Subeh
Right, this should be the simplest solution.
That's why I asked for AAA.
Best regards
Rolf
Hello
"I am dropped to a user mode prompt, not a Privileged"
line vty 0 xx
login local
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
with AAA enable, you can't configure "login local".
Subeh
@Subeth
According to the OP AAA isnt configured, so the reason why he is getting to exec mode is because he hasnt defined to use the local access credentials in vtty.
res
Paul
Thanks.
Kind Regards
Paul
@pdriver
AAA is activated, due to which login local will not be available.
Subeh
Hi Subeh,
I agree with you.
Alain
If aaa new-model is configured but there are no aaa authentication configuration commands then the result is essentially the same as login local.
I agree with Alain that the issue is not about authentication but is about authorization.
And the other alternative is to not worry about authorization and just configure privilege-level 15 directly on the vty ports. Since there is only one user who will be able to login I see no problem in automatically putting users on vty directly into privilege mode.
Rick
Rick
Hello
@Richard - I dont think just adding privilege level 15 to the vty lines will work when default AAA is active
AAA needs to be either disabled and have the login local added to the vty lines or keep the aaa enabled  add aaa authentication login default local
res
Paul
Thanks.
Kind Regards
Paul
Hi Paul,
I just labbed it and it works.
Alain
