Cisco Router not using configured privilege level
agchapman
Hi all, (all names etc are changed)
One of our clients is using a 2811 with only one account configured, as such:
username bdmin privilege 15 secret wordpass
and the enable password configured, in the running-config as:
enable secret 5 $1$mE92$SKx0DXmiCyPIWI/170LJE1
(I know this password, its just encrypted for accuracy)
"service password-encryption" has been turned on.
However, when logging in by telnet, using the bdmin username and password, I am dropped to a user mode prompt, not a Privileged. I have tried removing and re-adding the user account. It's the only one on the router, and removing the enable secret password just leaves me stuck in user mode.
I'm running 12.3(14)T5 code and can't work out for the life of me how to get a priv 15 user login working properly. Any ideas people?
Cheers!
19 Replies 19
Hello
So it does - having a bad day today - not thinking striaght
apologies to all
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Paul
NP. Having multiple sets of eyes reading the responses and checking them for validity is part of what makes these forums so great. We all make an occasional mis-step - I have certainly made my share. The important thing is that we have come to a better understanding of what might work for the OP.
Rick
Rick
Hello Richard
The thing about my reply to your post was I even tested it prior to posting then realised after I was connecting through my terminal  server (line console) and not vty lines -and also I posted the authentication command instead of the authorization exec one -
One again apologies to all for a misleading post.
res
Paul
Thanks.
Kind Regards
Paul
Hello Alistrar,
I think, one of these two solutions will help you
  1. Correct way
          username MYUSERNAME secrect MYPASSWORD
          enable secret MYENABLESECRET
          aaa new-model
          aaa authentication login VTY local-case
          aaa authentication enable default enable
          line vty 0 15
           exec-timeout 20 0
           login authentication VTY
           transport input ssh
          exit
          On this solution you will need to enter the enable password.
    2. Skip enable password
          add the following line
          line vty 0 15
            privilege level 15
          exit
          When you do this, you will automatical set to privilege level 15, when
          login via ssh and you will be placed inside the enable mode and the
          enable password will be skipped.
  But I would use the enable password for increasing security.
Kind regards
Kai
Wow! Thanks for the great responses everyone, and quickly to boot!!
I've kept new-model AAA enabled, and just used Alain's "aaa authorization exec default local" command and it has worked perfectly. Thanks Alain, and thanks everyone for contributing!
