cisco router VPN from HQ to many Branch?
rechard_david
Dear All,
now i would like to implement VPN from HQ to many branch. at HQ i have Cisco router 2821 and branches i have router 1841. the connection from HQ to branch i used fiber optic. after i configure VPN from HQ to branch, the connection from HQ to branch it up only one tunnel and other branch it not up.
please kindly see in the attach file.
Do you have some configuration or any advice?
Best Regards,
RE
7 Replies 7
Reza Sharifi
Rechard,
Can you post your configs?
Reza
Dear Sharifimr,
Please kindly see in the attach file.
Best Regards,
rechard
what happens if you use the same password for all the sites?
Reza
Dear Sharifimr,
it up only one branch. and other branch the tunnel is not up.
but i tried to change pre-share-key already it still the problem.
i would like to ask that , the confige that i did is correct or not?
i mean it right standard or not?
best Regrds,
Rechard
Hi Richard,
I have had a quick look at your configs and they look ok. Can you post show crypto isakmp sa?
Ross.
Dear Ross and all,
IPv4 Crypto ISAKMP SA
dst src state conn-id slot status
10.10.10.2 10.10.10.1 MM_KEY_EXCH 4002 0 ACTIVE
10.10.10.3 10.10.10.1 QM_IDLE 4003 0 ACTIVE
i tried to change the pre-share key already but it still show like this......
Best Regards,
Rechard
There looks like a problem with your keys not exchanging at phase 1. Try the command debug crypto isakmp to get more details on the phase 1. Just be careful when using debug commands on production networks you dont want to do it during peeks hours.
Ross.
