Cisco RV042G
samuelogalli
Hallo Friends
On the Cisco VPN router (RV042G), how do you configure NAT to map private IP to a static WAN internet IP address for internet access? Thanks you
5 Replies 5
check page 51 of the attached admin guide (section 'Setting Up One-to-One NAT'):
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv0xx/administration/guide/rv0xx_AG_78-19576.pdf
Hi Georg
Thanks a lot
HI
I have one single Public IP Adress. will it work with this One-to-one Mapping? Thanks in advance.
one IP address is sufficient. What exactly are you trying to accomplish ? One-to-one mapping is typically configured when you want to access an internal IP address from the outside...is that what you are trying to configure ?
Hi Georg
I what I want to archive is how I will configure NAT Overload from the 172.20.10.0 network to the 47.x.x.x single public IP address. please see attached sample illustration below. Thanks
