Cisco Rv134w connection problem to vdsl2 Centurylink Qwest
Hello !!! i have problem with RV134w routes , problem with vdsl connection to Centurylink , Qwest
i set ptm to login as ppoe
and constantly have a message connecting .............
something else i have to configure ? connection vdsl no match setting like adsl vpi vci
1 2018-04-29 1:32:01 PM alert pppd: PPP: Start to connect ...
2 2018-04-29 1:31:06 PM alert pppd: PPP: Start to connect ...
3 2018-04-29 1:30:12 PM alert pppd: PPP: Start to connect ...
4 2018-04-29 1:29:17 PM alert pppd: PPP: Start to connect ...
5 2018-04-29 1:29:17 PM notice pppd: pppd 2.4.1 started by cisco, uid 0
6 2018-04-29 1:29:17 PM alert ssk: ->(ssk) dsl_link_up 0 eth_link_up 0
7 2018-04-29 1:29:17 PM warn lldpd[3408]: no privilege separation available
8 2018-04-29 1:29:16 PM warn kernel: BCMVLAN : ptm0 mode was set to RG
9 2018-04-29 1:29:16 PM warn kernel: netdev path : ptm0.2 -> ptm0
10 2018-04-29 1:29:16 PM warn kernel: ptm0 MAC address set to xx:xx:xx:xx:xx:xx
11 2018-04-29 1:29:16 PM warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=5120000
12 2018-04-29 1:29:16 PM warn kernel: XTM Init: Ch:3 - 4700 tx BDs at 0xaa240000
13 2018-04-29 1:29:16 PM warn kernel: XTM Init: Ch:2 - 4700 tx BDs at 0xaa2a0000
14 2018-04-29 1:29:16 PM warn kernel: XTM Init: Ch:1 - 4700 tx BDs at 0xaa280000
15 2018-04-29 1:29:16 PM warn kernel: XTM Init: Ch:0 - 4700 tx BDs at 0xaa2e0000
you can either use 'Auto Detect' or manually enter the VPI/VCI values (see page 24 of the attached user guide)...
That said, make sure you have the latest firmware running on your RV134W (latest release is 1.0.1.11...
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv132w/admin_guide/en/RV132W_RV134W.pdf
Thank you , i just fix the problem , VPI VCI settings 0/32 , but the trick is you have to set vlanid to 201
