Cisco RV340-router13AD06 :client to site VPN configuration steps
Dear sir,
             i want to help for cisco RV340 router client to site VPN configurations..
my public WAN ip is 136.232.82.198 255.255.255.252 136.232.82.197.
my LAN ip is 192.168.15.1 255.255.255.0
help for Cisco VPN Client and 3rd Party Client.
please send full configuration steps..
Thank you.
which 3rd party client are you using ? The document linked below provides instructions for connectivity with Windows 10 clients...
https://community.cisco.com/t5/small-business-support-documents/pptp-vpn-configuration-on-rv340-345-routers/ta-p/3220097
nagrajk1969
For IKEv1-based 3rd-Party IPsec VPN Clients (such as GreenBow, Shrewsoft, Strongswan-based-VPN-Client, etc, etc), the below is the sample VPN-Sever (Client-to-Site server profile) config that you need to apply on RV34X/RV160x/RV260x routers:
RV/160/RV260/RV34X C2S IKEv1 VPN Server for Greenbow_Shrewsoft 3rd-Party Clients using PSK with Username-Passwds(Xauth)
- Configure the C2S server on RV34X/RV260/RV160 as below:
Step-1: In the user-groups/user-accounts (under System-Mgmnt page in GUI), create user-groups with user-accounts in these groups.
Step-2: In the Ipsec-Profiles, configure the below ipsec-algo-profile used by the specified clients as a sample example
Version: IKEv1
Phase-1: AES256-SHA1-GROUP2; Lifetime: 28800sec
Phase-2: ESP; AES256-SHA1; pfs=no; lifetime:3600sec
- apply and do a permanent save too
Step-3: Now in Client-to-Site section, click on "3rd-Party" radio-button (on RV34X only), and configure the vpn-server
In Basic Settings tab:
- add and configure a C2S vpn server as below:
Enable: Yes/Checked
Tunnel Name: Ikev1_3rdPartyClients_wPskXauth
Interface: WAN1
IKE Authentication Method
PreSharedKey: <enter PSK>
Local Identifier:
- select FQDN
- enter the value: servergw.test.local
Remote Identifier:
- select FQDN
- and enter a value: clientgw.test.local
Extended Authentication: ENABLED
- Select the user-groups
Pool Range for client lan:
Start ip: 10.31.1.100
End ip: 10.31.1.150
Step-4: In the Advanced settings tab
Ipsec Profile: Ikve1_Clients_Profile
Remote Endpoint : Dynamic IP
- It should be Dynamic IP only as multiple clients will be connecting to this server
Local Group Setup
Local IP Type: ANY
Mode Configuration
dns/wins/default-domain/etc: to be configured as per the user requirements
Step-5: Click on Apply and do a permanent save too
On each of the Greenbow/Shrewsoft and other IKEv1 clients among other configurations, the below settings has to be configured as common settings on each client:
1. Set the values for the below items in the ikev1 clients config:
Local Identifier: FQDN
<enter a value: clientgw.test.local>
Remote Identifier: FQDN
<enter a value: servergw.test.local>
2. BUT on each client you MUST use different username/passwords (and created before-hand in the user-group you had selected in the vpn-server config above).
NOTE: YOU SHOULD NOT AND CANNOT USE ONE SINGLE/SAME USERNAME-PASSWD(USER-ACCOUNT) ON ALL CLIENTS
thanks & best wishes
